broken tb vaccuum port?
07-06-2013, 01:20 PM | #2 |
Rep 109
07-06-2013, 01:56 PM | #6 |
Rep 109
Not sure what experience E90Company has at repairing this, but I do first hand. No need for a brass nipple considering it came as plastic from the factory. Buy plastic vacuum line connector sold at most auto part stores (cost $2.79). Make sure when you drill you start with the smallest bit and work up until hole is the correct size for the smallest connector. Put connector in hole of intake with crazy glue on it- let dry. Then put vacuum line back on once completely dry. Hope this helps!
07-06-2013, 02:51 PM | #8 |
Rep 109
07-06-2013, 02:57 PM | #9 | |
Rep 6,136
I recommend you do this rather than buying a new IM. I'd also recommend you use JBWeld as per the DIY, because it's stronger than glue and will provide a better seal for an area that experiences boost pressure. |
07-06-2013, 03:06 PM | #10 | |
Rep 109
07-06-2013, 04:18 PM | #13 |
Rep 719
You are better off joining plastic to plastic... I would use quick-set epoxy meant for plastics. I've made quite a few "repairs" like this back when I was a auto tech, you'll be fine!
ASE master tech (many moons ago)335xi- JB4 G5 iso/e50 custom flash/Custom meth/Borla mids/Custom x-pipe/DCI/ER charge pipe/Dual Ebay BOV's/Alpina B3 flash/Paddle shifter retro fit
07-06-2013, 05:10 PM | #14 | |
Rep 535
Have a nice day.
07-06-2013, 05:22 PM | #15 | |
Rep 6,136
07-06-2013, 06:28 PM | #16 | |
Rep 109
