cracking/popping noise from rear parcel shelf/windshield?
12-03-2005, 03:11 AM | #1 |
Rep 506
i've given up on trying to fix smaller rattles coming from the dash but this one is really bugging me. i get a cracking/popping noise that comes from the rear parcel shelf area while driving. it almost sounds as if something's gonna crack due to pressure.
it usually happens when i go over larger bumps and up driveways and is especially bad when i drive the car out at noon when it's hot (I assume it's due to the sudden temperature change since the car is cold when parked in the garage). i took it in to the dealer a few weeks ago to no avail. i actually drove the service advisor around the block and sadly it only happened once when he was there. a few days later, lo and behold, they told me they could not duplicate the problem but it's still there, especially when i first drive off. does anyone know what i'm talking about and has anyone had this fixed successfully either by the dealer or themselves? |
12-03-2005, 03:14 AM | #2 |
Rep 2,059
I've heard a rattling sound, but only when I drive over potholes and uneven road or terrain. Maybe the sports package setup is too stiff for the E90 parts to be silent.
330i 6MT l 255 HP @ 5900 rpm 214 lb-ft Torque @ 3500 rpm l Alpine White l Beige l Aluminum l ZSP l 494 l PDC
"Freude am Fahren" = "Joy to Drive" |
12-03-2005, 09:38 AM | #3 | |
Rep 123
2021 M340i Mineral White Metallic, Cognac
12-03-2005, 03:56 PM | #4 |
Rep 449
I have heard it too.
It seems to happen a lot when the heated rear screen is used in the frost, though I imagine you guys have never heard of one of those. I too believe it to be a material thermal coefficient thing. Daft that their cold weather testing didnt show this up mind... |
12-04-2005, 04:28 AM | #5 |
Rep 506
rad21, no i don't have the rear sunshade. i think in my case it comes from the rear parcel shelf since when i apply some pressure to the shelf, i get the same cracking noise that happens when i drove over bumps. it's certainly worst when there's a sudden change in temperature (e.g. driving car out of garage at noon) but just now i heard it a couple times at night after the car was parked on the street for a few hours in 50F temperatures..
12-04-2005, 10:27 AM | #6 | |
THE Viv
187
Rep 4,743
Drives: 330i SE
It stopped after about 10 minutes, once the rear screen was clear. |
12-04-2005, 03:17 PM | #7 |
Rep 56
I got the same cracking/popping sound comming from the back as well. My car went in for the service, and I drove around with one of the mechanics and he sure heard it. Now my car is going in for service again to fix this problem again comming wednesday. I will post the result as soon as get the report from them. It seems like your problem is exactly same as mine, so please let me know if you get this problem fixed.
12-04-2005, 03:21 PM | #8 |
Rep 1,238
I think it's the climate control system which causes temperature changes and therefore, ticking sound. Yesterday, I completely shut off the climate control system and the ticking/rattling is gone. As soon as I turn it back on, the ticking came back, and on almost every bump that I went through.
12-04-2005, 05:08 PM | #9 |
Rep 56
Rattle over pot holes
Is the rattle you hear coming from your B piller where the seat belt exits? If so, there is a warranty fix that involves the replacement of a washer. My 330 has the same problem and I am waiting for backorder of part to be filled.
12-04-2005, 11:39 PM | #10 |
Rep 4
I have the same problem with popping sounds from the back dash. I also get the seat belt clinking and more cracking sounds from the dash... I look forward to hearing about fixes for these from other forum members. I'm waiting on a back-order on the seat belt repair... I just can't believe it takes so long.
12-05-2005, 03:35 PM | #11 | |
Rep 506
12-18-2005, 04:01 AM | #14 |
Rep 56
Not exactly because I could not speak to the mechanic.
However, service adviser told me that they removed rear shelf and adjusted and tighten some stuff~ |
12-19-2005, 11:49 AM | #15 | |
Rep 506
12-19-2005, 05:42 PM | #16 |
Member
Rep 17
I experienced this early on. The problem is the rear glass is too tight onto the back shelf and causes creaking sounds. Fix is to ask dealer to move shelf away from rear window and then put some padding/felt down to prevent the rubbing.
This worked for me anyway.
E90 320d SE (Manual) - Black Saphire - Sports Seats, Sports steering wheel,158 wheels, Brushed Aluminium trim, Hi-Fi speakers, Sports suspension, Chrome grill and Mudflaps!
12-20-2005, 11:13 AM | #17 | |
Rep 506
06-02-2007, 10:41 PM | #18 |
Rep 1
I have a 335xi and I am experiencing noise in the door panel speakers and front dash...It is more noticeable when placing a call using the bluetooth phone...At times it sound like a high pitched vibrating noise...I tried turning the surround sound off which didn't help...Now I have it in theatre mode which is somewhat better. Anyways, I didn't expect this for such an upgrade...Does anyone have any suggestions? Thanks in advance.
06-02-2007, 10:50 PM | #19 |
Rep 1,038
Drives: X5
I got the same cracking/popping noise. It just started this past couple of weeks. It's probably the weather here getting warmer.
New: 12 X5 xDrive35i Premium Alpine White/Cinn Brown
Old: 08 E92 335i|Space Gray/Coral Red/Gray Poplar Old: 06 E90 330i|Black Sapphire/Black /Burl |
06-09-2007, 03:04 PM | #20 |
Rep 2
I had the same problem on my brand new 335i in the rear parcel. It did get worse in warmer temps.
I was able to pinpoint it to the plastic vent where the rear parcel meets the window. If you push down on the vent it should duplicate the cracking/popping noise. Instead of taking it to the dealer, I fixed it myself. I ended up removing the rear seat, rear air bag covers and lastly the rear shelf panel. That plastic vent screws in to the parcel with 4 screws. I removed the vent and used spray adhesive and 2" x 2" pieces of felt and glued them to the underside of the vent. Reassembled everything and the noise is gone. It took me about 1.5 hours which is how long it would take to drive to your dealer and hope they can confirm the defect. If anyone wants more info, let me know. |
06-09-2007, 09:54 PM | #22 | |
AC
95
Rep 2,387
FYI, he is still keeping his '01 330xi, apparently, he decided the "problem" is not significant enough for him to sell his car.
Your Supreme Leader
