Testing the OpenFlash OTS Stage 1 map with FBO+upgraded turbos
07-10-2013, 09:09 AM | #1 |
Team Zissou
3084
Rep 10,198
Yesterday I loaded up the OpenFlash OTS Stage 1 map and took the car for a rip. The first thing I noticed was how aggressively quick and precise boost onset is. It is so aggressive that my charge pipe blew off on the 2nd pull The funny thing is Shiv said the same thing happened to him testing this map on another car. Coincidence? maybe... either way it's probably not a bad idea to tighten down your charge pipe a little
This map is designed for a much less modded car, yet right out of the box with no tweaks it worked absolutely perfectly on my car (which has every bolt on and upgraded turbos). There were no boost control issues: no boost oscillation issues, no boost overshoots, nothing. It's neck breaking down low and buttery smooth up top throughout the pull. This is very conservative on my car (17.5psi at 4k tapering quickly to 13psi), but it's still fun to play with. It's especially cool to see boost control so perfect without having to mess with anything. I think you'll all enjoy this mapping |
07-10-2013, 09:16 AM | #3 |
Rep 1,079
I have a feeling my car is going to need a clutch soon after running these...
2004 E46 M3 | Imola Red on Cinnamon | Slicktop | Manual Seats | 6spd MT |
07-10-2013, 11:35 AM | #5 |
1750
Rep 17,960
Drives: A Lot
Thanks for testing JP! Our OpenFlash OTS maps do things a bit differently than what many OTS map users are used do with other flashing devices. They offer unusually good boost control and throttle modularity. Two things usually aren't associated with flash tunes. We have also mapped them in such a way that they shouldn't *need* any custom tuning to get them run properly (ie, without boost oscillation or strange jumpiness). Even when run on cars with a variety of mods/wastegates/turbos/etc,. Custom tuning will always help but I'd say it's for the last 10% of performance/drivability. Not the lasts 40% as has been the case from what I've seen.
07-10-2013, 12:18 PM | #8 | |
Team Zissou
3084
Rep 10,198
Logs will be posted when logging is enabled. My reactions are based on what I know the boost target to be vs. what i see on the gauges + what I feel. Once everything is released, and everything is out in the open expect tons of data. |
07-10-2013, 12:28 PM | #11 | |
1750
Rep 17,960
Drives: A Lot
It's a bit more convenient than having to log to the device and view later with laptop. But that option is coming soon too. |
07-10-2013, 12:46 PM | #13 |
1750
Rep 17,960
Drives: A Lot
07-10-2013, 12:46 PM | #14 |
Rep 1,079
I believe it is currently under development....so eventually.
07-10-2013, 01:19 PM | #15 |
Rep 1,392
Someone has to call jinks
Have a single turbo and/or tired of burning up O2 sensors? Ask me about the new ADV O2 sensor retro kits!
335i 2010 e92 M-sport Mods: VM Top mount 6466, Aquamist HSF4 w/custom direct port. VRSF IC + Exhaust 335i 2009 e90 665RWHP VFF900 ST RIP . |
07-10-2013, 02:01 PM | #16 |
Rep 1,079
Haha, I nearly edited mine to do that
07-11-2013, 10:48 PM | #17 | |
Rep 301
dont you have a procede? Have you tried using the procede to take a datalog? what do you have to do to run them stacked? |
07-11-2013, 11:06 PM | #18 |
Rep 776
Along the same lines....what about Procede+Meth? Map 4 with specific settings or new firmware to allow for both?
07-11-2013, 11:58 PM | #19 | |
Rep 1,185
If the pipe can pop off with the clip what tool would you need, just a flat head? |
07-12-2013, 12:05 AM | #20 |
Jedi samurai ninja turtle
621
Rep 3,021
Drives: X3 M40i 2018
How you controlling the meth jp? With the procede?
07-12-2013, 01:08 AM | #21 | |
1750
Rep 17,960
Drives: A Lot
07-12-2013, 01:22 AM | #22 | |
Rep 135
The factory chargepipe is designed well, apart from the fact it's made out of plastic! Under high boost it will sooner or later shatter at the c-clip connection |
