Another misfire thread
07-11-2013, 07:35 PM | #1 |
Rep 764
Hey guys so I'm still stuck on this annoying misfire. It says misfire cylinder 5 on the scanner..I changed the coil and it still gives me the code after deleting, hpfp and spark plugs were changed 2k miles ago, vanos solenoid was changed 100 miles ago. I did change the alternator the day before the problem begun. The engine keeps shaking and making a clunking noise. Only when it's cold it's undriveable. I have to keep turning it off and on then it drives normal and the power of the car is there. It's starting to become very annoying. Also, the reason why I haven't even looked at the injectors is because they had a recall on them about 10k miles ago so I don't think that will be the problem. Has anyone experienced this? Anything will help guys, thank you.
07-11-2013, 07:45 PM | #2 |
Rep 414
swap your injector...ex: #5 to #2 and #2 to #5...and see if problem go on cyl #2...
'08 BMW 335xi // Sedan // Black Sapphire // Sports Package//Mods: JB3 2.0|Unlocked 18ohm Board|BMS Meth Kit|AA Speed Delimiter|BMS tuning gauge|UR CL DP |BMS DCI|AA Exhaust|Helix fmic|CDV|H&R coilover| 10mm Spacers H&R on 4 wheels|**Record for XI's on dragtimes.com, 11.768s@118.70**Top speed 186,4 mph GPS, vbox 60-130mph at 10.18
07-11-2013, 07:52 PM | #3 |
Rep 105
IIRC don't you need to change the Teflon seal if you take out an injector, which requires a special tool to apply the seal? And then don't you need to replace both retention clips since they are one time use?
Vishnu PROcede 2.5SE, BMS DCI, Evolution Racewerk Charge Pipe, HKS SSQV4 |
07-11-2013, 09:05 PM | #6 | |
Rep 764
07-11-2013, 09:35 PM | #7 |
Rep 3,004
Well I had something similar, where the misfire was isolated to one cylinder. I did the same thing and replaced the coil and I still had issues. So I then swapped an old plug I had kicking around and everything worked fine. When the dealer replaces a coil, they are generally instructed to replace the corresponding Plug. I think when the coil goes it might somehow take out the plug as well.
It's worth a shot if you have an old plug kicking around. worked for me.
2007 E92 6MT SGM: MusicarNW Level 2, Procede Rev 2.5, FFTEC/Vishnu LPFP with Flexfuel Sensor and Flash, M3 Offset V701's, WaveTrac LSD, Michelin PSS, Downpipes, M3 Control Arms, TCKline D/A Suspension, LCI Tail lights, Lux AE's, ER Charge Pipe, DCI's, Mtech Front and Rear, M3 Sideskirts, HPF Stage 1 Clutch
07-11-2013, 09:36 PM | #8 | |
Rep 764
07-11-2013, 09:37 PM | #9 |
Rep 3,004
Cool...report back after you try that.
07-11-2013, 10:40 PM | #10 |
Rep 764
07-12-2013, 12:13 PM | #11 |
Rep 764
Hey so I opened her up, changed spark plugs 5 and 6 with 1 and 2, as well as the coils..the spark plugs were all black and I changed it 2k miles ago..I'm thinking there is a air leak maybe? What do you think!
07-12-2013, 12:50 PM | #12 |
Rep 764
Okay guys I believe it's a air leak, when I was installing back the coils and stuff, I was doing an injector swap and a hose with a clip from the injectors to another entrance wasn't click on to the pipe so I believe it's a air leak as 5 and 6 spark plugs were black big time and not the other ones, I took some pics I'll post it once I get home!
07-12-2013, 01:27 PM | #13 |
Rep 764
Okay guys here are some pictures...It was loose in the begining and imo i think it is still loose. But i guess it wasnt clicked onto the pipe in the beginging so i need some opinions on this. Is it suppose to be loose or is it suppose to be tight? Any feedback will help! thanks everyone for the help!
07-12-2013, 02:05 PM | #15 |
Rep 764
07-12-2013, 03:23 PM | #16 |
Rep 3,004
Yes...this would cause air leaks for sure...How does the car drive now?
07-12-2013, 03:32 PM | #17 |
Rep 764
07-13-2013, 02:19 PM | #18 |
Rep 764
Okay guys, after turning the car after switching coils and plugs 5 and 6 with 1 and 2..the clunking became more, the engine was working worse, bunch of smoke coming out of exhaust, like A LOT of smoke, car at the moment is bone stock no mods, I'm going to my techs shop after work and checking out the codes! Anyone experience this? Thanks
