Cobb with BMS Meth
07-12-2013, 04:08 AM | #2 |
Rep 7,377
what do you mean connect??? as failsafe? you dont connect to cobb but to the dme itself.
07-12-2013, 05:07 AM | #3 |
Jedi samurai ninja turtle
621
Rep 3,021
Drives: X3 M40i 2018
You need an aquamist meth controller
07-12-2013, 06:04 AM | #4 | |
Rep 135
What do you currently own?
Not necessarily...only if he already has a Cobb and doesn't want to stack tunes. |
07-12-2013, 06:40 AM | #5 |
Rep 7,377
lol thats what the op wrote. no need to repeat it. more info is needed...
07-12-2013, 11:16 AM | #8 | |
Rep 7,377
Best kit out
07-16-2013, 02:40 AM | #10 |
Rep 7,377
u can run any kit you want but only the hfs4 is integrated to create a failsafe with cobb. it also works using injector signal and boost. so run your bms kit but if your map is very aggressive and it fails to spray you can hurt stuff.
07-16-2013, 02:52 AM | #11 |
Rep 135
You need to buy a JB4 to control the BMS meth kit. You can either sell the Cobb or use it for BMS's backend flash. If you can still get around $600 for an AP in the used market, I would unload it and buy an OpenFlash tablet for $395 if you decide to do a backend flash later on.
07-16-2013, 02:58 AM | #12 |
Rep 135
The spray and pray approach is not advisable. Meth kits fail all the time. The last thing you want to do is blow a cylinder and destroy your engine running too much ignition advance under load
07-16-2013, 05:14 AM | #13 |
621
Rep 3,021
As I stated above, if you want to run a Cobb flash only - then you will need the aquamist.
Otherwise, get a JB4 with the FSB on top of the BMS flash. You can't run a BMS flash on its own anyway. |
07-16-2013, 07:36 AM | #14 |
Rep 3,732
Drives: BMW S1000XR
BMWCCA member |
07-16-2013, 10:08 AM | #16 | |
Rep 2,626
now with that, the easiest way for you is to get a boost switch and set it to something like 7 or 8 psi. you won't even have to connect to the DME and you're all set. of course you have no failsafe with that method.
'18 F80 M3 Comp 6MT - Stock
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar. '05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT | '07 E90 335i, PTF COBB E50, FBO, HFS4 |
07-17-2013, 09:33 PM | #17 |
Rep 783
FSB is really limited in failsafe ability. Speaking to some locals running it they always have issues with the thing burning out and having to replace it. It also just guesses on actual flow unlike Aquamist that sees real liquid flow. Once the kit is spraying there is little difference but the advantages are everywhere else and they are critical to engine health and safety.
'07 335i E90 - PTF ProTUNED by Dzenno - COBB FMIC - AFE DCI - AA DPs - HFS4 Meth
'09 M3 - Stock |
08-02-2013, 08:05 AM | #18 |
Rep 1,504
08-02-2013, 05:14 PM | #20 |
Rep 1,202
I second the HFS-4 it's a great kit with a lot of features and honestly your only option if you want to run a meth kit with intregrated failsafe and flash only. Snow has something called safejection, but I have no experience with it.
