Shifting Weird, Help!
07-13-2013, 10:41 AM | #1 |
335i Owner
58
Rep 839
Drives: BMW 335i 4 Door
My car is getting a backpressure jolt on the decel of 5 MPH and lower. The car jolts and almost "freezes" when it does, any idea? This doesn't happen everytime but, if I slowly let it decel, it feels like it gets a jolt of backpressure going through the exhaust.
E90 - 2007 BMW 335i Sedan
45K miles 7" VRSF FMIC | BMS DCI | AR Catless DPs | KW v2 Coilovers | M3 Front Control Arms |
07-13-2013, 02:54 PM | #2 |
335i Owner
58
Rep 839
Anyone...?
07-13-2013, 03:40 PM | #3 |
The bigger they are...
18
Rep 264
Manual or Automatic?
Tom Williams BMW Service Advisor
'07 335i Sport 219M Wheels, MMW CF Lip, Shadowline Taillights, Vishnu Procede, BMS DCI, BMS OCC, Aasco LW Flywheel, South Bend Clutch, Turner 90mm Studs, Stoptech pads rotors and lines, BMS LED Tag Lights, BMS Clutch Stop, BMS Clutch Non-Delay Valve, ACS Style Rear Glass Spoiler |
07-13-2013, 03:44 PM | #4 |
335i Owner
58
Rep 839
07-13-2013, 04:54 PM | #6 |
335i Owner
58
Rep 839
In drive mode only, sport mode feels a bit jolty (because the downshifting) this isn't a downshift more like my car freezes and just spits a quick back pressure through.
07-13-2013, 06:48 PM | #7 |
335i Owner
58
Rep 839
I was told this could be my torque converter... isn't that crazy expensive to fix? I have an extended warranty on the engine and transmission, bought the car less than 3 months ago.
Does anyone else think that it's the torque converter?
07-13-2013, 08:13 PM | #8 |
335i Owner
58
Rep 839
Anyone experiencing the same thing?
07-14-2013, 11:17 PM | #9 |
335i Owner
58
Rep 839
Anyone?
07-14-2013, 11:21 PM | #10 |
Rep 2,172
This is a common issue with the ZF transmission because of the electronic stall on the torque converter. I said it was the torque converter, but I never said it was an issue. It's not an issue and it's just something you'll have to live with unless your transmission is not running the latest flash and programming. Once you get your cable, we can check that as well as resetting the adaptation which could clear it up.
07-14-2013, 11:25 PM | #11 | |
335i Owner
58
Rep 839
07-15-2013, 08:32 AM | #12 |
Rep 2,172
