e85 70%
07-17-2013, 01:24 PM | #1 |
Rep 886
e85 70%
I'm fbo on friday.Can't wait)))
I defenitely want to try E30 maps, but as far as i know the best way to use e85 is PTF. And i defenitely want to deal with them,but for much higher mixtures of e60 or e70. So the question is which upgrades i need? Lpfp walbro 455? What else is needed? Please chime in!
Bmw 335xi/FBO/ black on black/ 6sp manual/Cobb AP/BMS DCI/AA BOV KIT/VRSF DP'S/VRSF 7'FMIC /FULLY CATLESS/H&R sport springs/ 19' ac schnitzer wheels.
07-17-2013, 01:32 PM | #2 |
Rep 6,478
You’ll need a LPFP upgrade, whether you choose an inline or in-bucket solution is up to you. You should be able to get into the E70 range with just that, and then the appropriate tuning of course.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
07-17-2013, 02:51 PM | #3 | |
Rep 886
I just need to order walbro 455 and deal with PTF and that's it? Any tools to install the pump or smth else???
07-17-2013, 03:01 PM | #4 |
Rep 6,478
To just run and tune off of E70, yes all you should need is something to up the PSI for LPFP. Again, inline or in-bucket will alter costs, flow, labor required, etc. Terrys forum has a lot of info on the two methods. Assuming you can provide the fueling required, PTF will be able to tune for E70 no problem. It doesn’t take much to run a lot of E85, which is one of the advantages of the fuel.
07-17-2013, 06:13 PM | #5 | |
Rep 886
Is it really a DIY mod??? Any pictures video info???
07-17-2013, 06:33 PM | #6 |
Rep 6,478
Inline is DIY. In-tank is DIY technically, but i've read over so many people who have tried and failed to correctly install it. Any time you remove the OEM pump from the bucket, you better be thorough on the replacement or it could fail. Inline is the superior solution in my opinion.
http://lmgtfy.com/?q=n54+inline+walbro
07-17-2013, 06:43 PM | #7 | |
Reborn
87
Rep 1,217
This is assuming you have an upgraded LPFP. |
07-17-2013, 07:15 PM | #8 | |
Rep 886
07-17-2013, 08:03 PM | #10 |
Reborn
87
Rep 1,217
07-18-2013, 06:32 AM | #11 | |
Rep 886
Best for me is to plug it one's and use it, i don't wanna hassle with different stuff...
07-18-2013, 06:33 AM | #12 |
Rep 886
Which is easier option to install and use???
07-18-2013, 08:26 AM | #14 |
Rep 886
Where can i find such pumps, what is the name of the product???
07-19-2013, 07:46 AM | #15 |
Rep 190
Just a thought. How do you know you need inline, LPFP etc? Have you logged FP ? I run e65 - e70 daily on all stock components. Any more than that I lose FP on extended pulls.
Instagram: "mattyates85" FB: "Matt Yates"
2013 335iS DCT, Alpine/Saddle JB4, BMS Flash, DCI, RECORD 1/4 JB4/Flash ONLY: 11.9 @118 mph After Dp's installed: 11.57 @120 mph(best trap 121 mph) |
07-19-2013, 08:47 AM | #16 | |
Rep 6,478
Some people have been able to get away with e50, but more than that and you start to get very tight on fueling. |
07-19-2013, 09:46 AM | #18 |
Rep 162
I've been running E50 on my stock fuel systems and I've been hearing about people upgrading their pumps, but what exactly is going on? I've read through Terry's forum about the inline fuel pump option, and I've also read about people using HPFP and LPFP? Are there two pumps in our system? And what's PTF? Can someone please give me a quick run down?
FBO Instagram: RickyyyyyH |
07-19-2013, 10:28 AM | #19 | |
Rep 6,478
Have you been logging at E50? You really should. That’s getting aggressive for the stock fueling. PTF= Pro Tuning Freaks. A tuning outfit that uses the Cobb flash to build custom maps for any application under the sun. Awesome work they do.
07-19-2013, 11:59 AM | #20 | |
Rep 162
07-19-2013, 12:06 PM | #21 | ||
Rep 1,946
07-19-2013, 12:17 PM | #22 |
Rep 6,478
Do not run E50 on a whim. Go down to E30 and lets make sure the hardware is flowing well enough. Log.
