lower CR piston..
07-21-2013, 06:28 PM | #3 |
Rep 748
So you would make less power with stock turbos as the limiting factor is the turbos up top, not the octane in most cases. But with a big turbo you could make more boost on the same fuel as E90Company said.
2008 335I E92, AW, VFF700, 18" Forgestar F14, M3 front/side, M-tech rear, AMS IC, H&R Touring Cup Kit suspension, HID AE, ER Charge Pipe & Synapse BOV, CIC Retrofit, Quafie, DSS, Defiv Lockdown, SPEC 2+/Steel SMFW, Walbro 450
07-21-2013, 07:11 PM | #4 |
Rep 538
Using the same boost and lowering the CR would give you less power.
Two reasons to lower the CR is so you can run really high boost or so you can have a better safety margin with low octane pump gas. |
07-22-2013, 11:31 AM | #5 |
Rep 1,595
Drives: 2011 335i xDrive Msport
And the biggest benefit to running lower CR is that you get the same static compression ratio by running higher boost, but you get to cool off the compressed air with the intercooler. By using higher compression pistons the air is heated from the compression and not cooled.
07-23-2013, 12:59 PM | #7 |
Rep 1,595
It is an extremely small difference, as is very slightly decreased torque, but more power up top. Everything is a tradeoff. With stock turbos it is pointless though because they are tapped out anyway.
07-23-2013, 02:28 PM | #9 |
Aficionado of All Things Vroom
177
Rep 1,216
Current: 2020 F97 X3M Competition
Retired: '18 6MT AW F30 340x Drive | '15 6MT F80 M3| '11 AW DCT E92 M3| '09 6MT AW E90 335i| 08' 6MT E92 328xi |
07-23-2013, 03:04 PM | #11 |
177
Rep 1,216
