07-22-2013, 08:03 AM | #1 |
Rep 263
coding help me
hello,
I live in Belgium and my English is not good, so I translated with google, sorry. I am newbie in the coding and a problem. I have cable and ESYS_v.3.18.4 and v.48.2_SPdZ. I followed the procedure pdf Part 1 only on step 11 it goes wrong,I select the CADF line, then "Read Data Coding", he writes error, so that 's right, but I do not have a new folder that appears as point 13 pdf what is the problem please help me pdf part 1==> http://www.f30post.com/forums/showpo...71&postcount=1 Uploaded with ImageShack.us |
07-22-2013, 08:50 AM | #3 |
Rep 263
07-22-2013, 01:12 PM | #4 |
Rep 263
I managed to read the data encoding, but not all and I do not know why.
Then when I made a right and "edit fdl" click it asks me for a pass word. what is the pass word Uploaded with ImageShack.us thank you |
07-23-2013, 05:34 AM | #6 |
Rep 3,227
07-23-2013, 06:07 AM | #7 | |
Rep 263
I was told that the token was available on the internet for this version of ESYS_v.3.18.4, but I do not find them. who can give me please |
07-23-2013, 09:24 AM | #13 |
Rep 263
one more question,
here is what is written in pdf ==>Step 13: New option under CADF, a folder. Expand the folder by clicking + and right click that file, Select “EDIT FDL but I'm sure it will CAFD file when I made the manipulation does not create a new folder. why? |
07-24-2013, 12:18 AM | #14 |
Rep 3,227
Im not exactly sure what you mean?
The picture you have in post #4 from what I can see IS step 13. The blue CAFD highlighted is what you are going to code. Once you have inputted the token it "should" take you to the actual ECU you need to change the Werte values, which is step 14. Good luck H |
07-24-2013, 02:24 AM | #16 |
Rep 3,227
You don't need to do it for all CAFD's?
You only do it for those you want to change. For example, you would probably only need to use the Fem body, ACSM, HU CIC/NBT, Kombi and REM ECU modules, therefore you don't need to touch the other CAFD files listed. In the pic #4 above you have highlighted the AMP module. I don't even know what that does and it's certainly not something I ,or anyone I know of, has needed to change. Hope that helps mate. H |
07-24-2013, 07:03 AM | #17 |
Rep 263
thank you very much, your answer really helps.
I found the cheat sheet for f30, how to know is to make the change. eg I would like to activate the drive connected, or that it is you this is what I aimerasi coding - Enable beep opening and closing car -enabled camera rolling -activate video in motion -to the sound of the alarm type U.S. -display speed -display tire pressure etc. know how or because it is on the cheat sheet there is no information of where it is. https://docs.google.com/spreadsheet/...Ia3ZmbUE#gid=0 really thank you because without your help I would not get there |
07-24-2013, 07:26 AM | #18 |
Rep 3,227
Sorry, Google translator has really made a mess of what you said.
Here are other cheat sheets which I think might contain some of the things you are after, such as the individual tyre pressures and digital speedo. http://www.f30post.com/forums/attach...1&d=1371060638 http://www.bimmerfest.com/forums/att...9&d=1339114795 Good luck. |
