Lower ur temp
07-22-2013, 06:23 PM | #1 |
Rep 1,909
Lower ur temp
Guys, I didnt put the splash shield underneath to observe any leaks and it turns out I'm running 225 - 235 ... it used to be almost 250 before
I also changed the diverter valve but that shouldn't affect temp I guess more air underneath the engine is helping air out some of the exhaust heat.. |
07-22-2013, 06:25 PM | #2 |
Rep 722
This doesn't surprise me at all
11' m57 335d 165k Miles - JR 2, ATM Full Exhaust & Intake, Wagner FMIC, AAR Boost Pipe, AAR Swirl Delete, AAR EGR Delete
08' n54 135i FBO E85 - SOLD |
07-22-2013, 07:59 PM | #3 | |
DIYER
614
Rep 5,521
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
07-22-2013, 09:15 PM | #4 |
Rep 134
There are also electrical connectors sitting right above the splash shield (water pump and thermostat connectors come to mind). I'm sure the plugs are sealed at least somewhat but the less water that can splash up there, the better.
If you want to lower your oil temp, get a better oil cooler (or get one in the first place depending on which N54 setup you have). |
07-22-2013, 11:35 PM | #6 |
Rep 1,185
Almost all cars out there dont have a splash shield. The whole purpose of it is for the oil leaks, coolant leaks ect... but if you have a big leak it would seem through anyways. The only cars that use it for other reasons are hybrids. It helps with gas mileage by keeping the flow of air under the car instead of in it.
The other day i asked myself this same question, why even keep it on. This is a turbo car and it already gets really hot, all that shield does is keep the hot air inside the engine bay, with it off it will cool much faster and cool while driving. I'd say keep it on if you dont want to deal with the hassle of taking it off but if you want lower engine temps take it off. I'll probably be doing the same if i order some downpipes. I dont have an oil cooler on my car and my temps average 240 as well. The highest ive seen is 250 and thats after flooring it. Its possible the oil helps, I'm running 0w40 mobile 1 oil for (bmw's). I'd suggest anyone who gets higher than 250 temps to keep the splash shield off. I would also remove it with upgraded turbos. A vented hood would also help and create a cooling effect with the splash shield off. |
07-23-2013, 12:13 AM | #7 | |
Rep 60
Also, most modern cars will have splash shields and the ones that don't are usually the economically stripped down versions that are bare. This is the result of the manufacturer saving money where they can. Also, why is everyone assuming that cooler oil temperatures is some how better? What if the engineers designed the engine to run at optimal temps of 240F which is standard. I understand that the margin from 225F - limb mode is greater then from 240F - limb mode but if your car is not being pushed to these upper limits, what is the real point of cooler oil temps? |
07-23-2013, 01:31 AM | #8 |
Rep 172
Well the point of cooler oil is to allow the oil to get into the 'zone' and then to keep it there, the stock cooler does a crap job of keeping it in the zone, hence limp mode, so if you can help the cooler along a bit by providing more air flow, you should be able to stop limping at least a little bit longer
07-23-2013, 10:30 AM | #9 | |
3442
Rep 79,211
The way I see it most people like myself are used to a vehicle that can maintain "normal" oil temperatures. I.E. 99% of every other vehicle on the road aims for somewhere in the 170F to 215F oil temp. This car has trouble maintaining under 250F especially when pushed hard. A majority of the so called reasoning for these higher oil temps was apparently less "pumping loss". The reality is this car also has coolant running through the turbo's too. So if your coolant is at 210-220F or a little less during normal driving conditions I would be hard pressed to see temperatures below that all said and done. |
07-23-2013, 10:51 AM | #10 |
Rep 162
Woe, wouldn't expect to see that much decrease in temperature, insteresting topic though.
FBO Instagram: RickyyyyyH |
07-23-2013, 10:53 AM | #11 |
Rep 1,381
One mod that works is the bms thermostat (provided you have an adequate oil cooler) . Ive never crossed 250 even on the track with 95 degree summer heat. The under panel is for aero
07-23-2013, 12:21 PM | #12 | |
Rep 1,185
Some cars without factory oil coolers get well int he 275 range and well thats just way to high and can be dangerous since oil breaks down at higher temps (350 for synthetic) and running it at 275 or higher would mean alot more oil changes. People can look at it as a cooling mod, or as something that shouldn't be done. Everyone has good points, but your making it to the people with an oil cooler. Although the op might have one this would be a nice mod to bring down those cars that run at 260-275 cars and have no oil coolers. Since oil coolers are $1500 plus (when not having a stock one) its a cheap solution for anyone not willing to pay more to have it added since bmw decided to not put them in all 335's. |
07-23-2013, 12:55 PM | #13 | |
Rep 1,381
you are correct only if you have an oil cooler this mod would work. I thought bmw had a sib to install a free oil cooler for the cars that didnt come with any. Maybe a higher w oil might help also. Thats messed up that there are n54's without oil coolers.
07-23-2013, 01:47 PM | #14 | |
Rep 2,014
WedgePerformance E40 MHD | Performance Exhaust Mod | BMS DP | Vibrant 1790 | BMS Intake | VRSF CP | xHP Stage 3 Michelin PSS | M3 Control Arms LUX v4 LEDs | Shadowline Grills | Lip Spoiler |
07-23-2013, 02:43 PM | #16 |
Rep 1,185
07-23-2013, 02:45 PM | #17 |
3442
Rep 79,211
If your BMW is not equipped with a BMW oil cooler but is prone to many limp modes you can sometimes get BMW (not with ease) to retrofit one in out of goodwill. I've seen it happen but you need a few instances of going into limp mode and some leg work to get it done for free.
07-23-2013, 03:21 PM | #18 | |
Rep 1,185
Is there a mileage limitation on getting them to do this retro fit if it ever ends up in limp mode? I drive in 100+ weather quite often and im surprised its yet to get above 260 without an oil cooler. |
07-23-2013, 04:25 PM | #19 | |
3442
Rep 79,211
Your typical road use and commuting should not have a problem maintaining 250F. I dont know the logistics of what dealers if any will offer a retrofit out of goodwill. I've only heard stories of people getting them done out of goodwill. I would imagine it would need to fall atleast within warranty period of the vehicle. I would also assume they needed to have multiple instances of limp mode and probably had to get BMWNA involved too. |
07-23-2013, 04:42 PM | #20 | |
Rep 1,185
Or maybe the carmax warranty company part of it will just say, well if it blows we will just replace it lol. |
07-23-2013, 05:44 PM | #21 |
Rep 414
My 08 non sport model does not have an oil cooler. I have not seen it go much more than a tick over 250 even when its 110+ outside. I have also never tracked the car so
I don't think your gonna have much luck getting something that doesn't exist replaced/added on an aftermarket warranty but GL
"And just one question I might ask yah, and it might sound like A disaster, can you make this thing go faster?"
07-23-2013, 05:58 PM | #22 | |
Rep 1,185
When i first got it the temps ran about 250-260 average in 100+ degrees. Then i swapped to ngk (1 step colder plugs), coolant flush with 50/50, a bottle of super coolant, a 7" vrsf intercooler, and 0w40 mobile one oil (recommended oil by mobile 1) and now i average 240 and on a normal cruise its at 235, but when i hit the gas (for enjoyment) it will spike up to 245-250 and drop back to 240, then slowly reach 235. (this is with the splash shield btw). I recently started putting in 30% ethanol and the car pulls much better, it also seems to not jump above the 250 temperature anymore after a nice 1-3 gear run, like it used to and i still hover around 235-240 degrees. I've never really done multiple runs since i need to hit the track for that, but after one semi good run its holding good. At this point an oil cooler doesnt seem like its needed (for me at least), but i'm sure as the car ages more things will change so it'll be something down the road to look into. Right now im looking into the vishnu e85 kit and running fuel e85 should help keep my temps down even more. For anyone having temp problems, try out (1 step colder plugs, 0w40 mobile oil, or royal purple) and super coolant, and run a mix of ethanol (if you have it). You might be surprised to see a 10 degree drop in average temps across the board as long as the rest of the car is up to par. If this doesnt work, then get an oil cooler. |
