Suspension and hopping over bumps
07-26-2013, 06:01 AM | #1 |
Rep 66
Hi,
I have noticed when pressing on, if there is a little bump on the corner the car feels like it hops a little and the DTC flashes. Is this normal for e92s? Admittedly the roads near me arent brillaint, but my old Evo 6 had coilovers and didnt hop. Is this a tell tail sign of worn suspension components? Its generally quite a good ride for the most part. Cheers |
07-26-2013, 06:16 AM | #2 |
Rep 2,337
If you are flooring it over bumps with DTC off (traction control on) this is pretty common. You are just getting a bit of slip between the rear wheels. Press the DTC button and it will go away. There is a bit of road by me with a little camber and had a slightly rough surface due to some minor potholes until till they filled them. Every time i went over these bumps DTC would flash even at 30mph.
07-26-2013, 07:36 AM | #3 | |
Rep 66
07-26-2013, 07:43 AM | #5 |
Rep 3,201
Drives: E92 325i MSport Coupe
Fit a set of KONI FSD dampers.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
07-26-2013, 07:50 AM | #6 |
Rep 66
07-26-2013, 07:51 AM | #7 |
Rep 66
07-26-2013, 08:54 AM | #8 |
Rep 2,337
M Sport suspension with run-flats is a pretty horrible ride on the bumps. It does feel juddery at times.
You compare with an Evo VI, but remember this car weighs 250-300kg more and is RWD. It will never grip like an Evo. |
07-26-2013, 09:28 AM | #9 |
Rep 66
Oh yeah course, i'm not comparing the grip to the evo and it grips just fine for a road car anyway, it was just the noticable hopping on the bumps, even the missus Astra doesnt do that, but it could be the run flats I guess
07-26-2013, 10:20 AM | #10 |
Rep 2,692
before you spend change the rfts to non rfts and then judge from there whether you want more grip etc because the difference between rfts and non rfts is like chalk and cheese...its that much of a difference!
07-26-2013, 10:37 AM | #11 | |
Rep 66
But yeah, ill be changing to non RFTs when they are worn out |
07-26-2013, 11:03 AM | #12 |
Rep 3,201
07-26-2013, 04:09 PM | #13 |
Rep 2,692
Probably me who phrased what i said out of context to be fair BUT fact still remains...i used to get the skipping on rfts but it more or less disappeared on non rfts
