angel eye bulb
07-26-2013, 12:44 PM | #1 |
Rep 73
angel eye bulb
Hello has any one tried these angel eye upgrade bulbs, bit strapped at mo trying to do it cheapish, I did read LED are not the brightest in the day so nit sure what to go for Cheers
http://www.xenons4u.co.uk/bmw-led-an...bulbs-kit.html |
08-21-2013, 08:54 AM | #2 |
Rep 2,445
Drives: 2018 630iGT sport
I think you need 60w or more to be bright.
I tried some 10w ones and returned them, as the standard bulbs are brighter. To be honest, it also concerns me a little about the size of the heat sinks on some of these LED ones, and frankly I'm not that comfortable about fitting LED lights (of unknown origin and quality!) that look like they must generate a ridiculous amount of heat into the confined, enclosed space of my headlights. |
08-23-2013, 06:15 AM | #3 |
Rep 73
Cheers I went with some 64w 7000 Cree led from this very site crystal white is the make/company name they are the business £100 not the cheapest but as bright as the standard bulb absolute fucker to fit but yeah real good cheers Ish if your reading this
08-23-2013, 12:17 PM | #4 | |
BimmerPost Supporting Vendor
472
Rep 4,938
08-23-2013, 01:34 PM | #5 |
Rep 2,445
The wattage is stated, as far as I'm aware, so people have some idea of the light output in terms of what the equivalent standard bulb is. Lux or lumens just confuse everyone.
There must be some difference, as if they all stated 6-7watt, they'd all have the same kind out light output surely? What light output a yours then? Do they also have a heat sink the size of a golf ball, or are they smaller? It's all a bit confusing to be honest, CREE I thought was the nuts, but turns out there's a few variations of those too! |
08-23-2013, 02:12 PM | #6 | |
472
Rep 4,938
08-23-2013, 03:00 PM | #7 |
Senior Troll
225
Rep 3,378
A florist will always say they have the best flowers.
Gone:
N54 335i is the Legend! N55 435i Now: 718 Cayman GTS / F83 M4 |
08-23-2013, 03:57 PM | #8 |
Rep 2,445
Quite. Another reason I took mine back was because the billet aluminium doesn't fit securely into the headlight, as the standard bulbs are shaped such that they slightly sprung, and you can feel them lock into place. I yet to see an aftermarket one that replicates this. They are all Cnc machined aluminium with flat tabs. Fwiw, I like the colour changing arrangement yours have. That's pretty cool. Last edited by Russbmw; 08-23-2013 at 04:05 PM.. |
08-23-2013, 08:07 PM | #9 | |
Senior Troll
225
Rep 3,378
If you the best of the best, get joshsha's led . they are the Bulls!! less costly than lux too http://www.liteangels.co.uk/#!services/cb3i
Gone:
08-26-2013, 11:53 AM | #10 |
472
Rep 4,938
A florist only resells flowers they buy from a distributor. We have engineered these lights, set up the manufacturing, and spend so much time, money and effort in the R&D of it. I get your analogy, but its really not the same
