Vishnu/FFTEC: 738WHP with 6466 Twin Scroll (New World Record)
07-27-2013, 02:11 AM | #1 |
1750
Rep 17,960
Drives: A Lot
Captain Insano's 2007 e90 6MT is going to break some hearts. As well as all of our old, yet still standing, 1/4 mile and 60-130mph world records!
Details: 2007 335i 6MT Lots of miles (over 70k) Lots of track time at Laguna Lots of oil coolers Some ridiculous clutch with LWFW VFF in-line fuel pump Upgraded fuel rail Bilstein Coilovers Flared fenders with wide wheels wrapped in Toyo R888s VFF900 (6466 Twin Scroll) Vishnu PWM Meth Procede+OpenFlash Tablet Since the last time we tested the car, it make a healthy 700whp at 26psi. Since then, it has been converted over to a disturbingly beautiful twin scroll manifold. Looks about the same from up top, but when viewed on the engine stand, it's a work of art. It's so well fabricated I want to punch myself in the face whenever I look at it: The turbo has been upgraded to a larger 1.0 hotside with divided housing (twin scroll). This means dual wastegates and a lot more work for the fabricators (see above). Today we finally got some time to visit a Dynojet at DNR Performance, Hayward CA. FFTEC's in-house Dyno is a Mustang Dyno and, while great for initial calibration/tuning, its not the best for dyno comparisons since it's so configurable.. as it should be for tuning!). Our goal was to run 27-28psi and see what this magic turbo can do. First several runs of the day were at 24-25psi: Datalog: Another datalog: No matter how much we raised boost target up top, we couldn't make any more peak power. Power just stopped climbing at 6700rpm, limiting power to a disappointing 707whp. The datalogs revealed that we weren't hitting our boost targets above 6700rpm. No matter how much WGDC we added, nothing helped. Turns out we the 10psi WG springs weren't stiff enough to be controlled over 25psi using the dual port wastegate control solenoid set-up we decided to use. The dual port set-up offers incredibly good accuracy and resistance to overshoot. But with all electronic wastegate control setups, you need to choose your mechanical WG spring just right (not to stiff, not too soft) and this is often a trial and error thing. So you say this is one of those errors. Refusing to go back to the shop, install stiffer WG springs and come back next week, we decided to get a little creative. So we changed the wastegates boost reference signal from the nipple on the turbo's compressor housing to a nipple on the intake manifold. What this essentially does is compensate for a little pressure loss cause induced by the FMIC. Which should mean just a tad bit more boost up top. Not the 28psi (775+whp) we were targeting. But just maybe 25.5. It worked. Just barely! 738whp. Not close to we were aiming for when we first came to dyno tonight. But at least good enough to break the existing world record by a good margin. And more importantly, with broader, much more useful powerband. Did I mention this thing holds power until the rev limit @ 7300? Datalog: And sometime during this dyno session, I inadvertantly did a run in Map1 (low boost (22psi) with no meth: Next: Stiffer wastegates are going in next. Then back to the dyno to run at full boost. And then 60-130 acceleration tests (high 5s or go home!). And then to the dragstrip to break my own N54 WR time of 10.8@132 from last year. Compared to my car, this car is making about 100whp more with way more top end power. It should run low 10s Big props to Captain Insano for being insane enough to let us build and tune something like this for him to drive on the street and race on weekends. Best Regards, Shiv PS. Video to come next week. The car sounds rad. Way different than our previous single scroll single turbo cars. Last edited by OpenFlash; 07-27-2013 at 12:28 PM.. |
07-27-2013, 02:44 AM | #3 | |
Rep 1,392
Have a single turbo and/or tired of burning up O2 sensors? Ask me about the new ADV O2 sensor retro kits!
335i 2010 e92 M-sport Mods: VM Top mount 6466, Aquamist HSF4 w/custom direct port. VRSF IC + Exhaust 335i 2009 e90 665RWHP VFF900 ST RIP . |
07-27-2013, 02:45 AM | #4 |
Rep 574
It's a custom twinscroll on a n54 engine. Stock longblock afaik. Impressive numbers for sure, what turbo is this again?
Twin scroll or twin fans is where it's at imo. |
07-27-2013, 02:47 AM | #5 |
Rep 1,392
Awesome numbers! A little confused about the limiting factor as stated on FB. I would like to see the captains single vs twin scroll overlay perhaps boost too.
07-27-2013, 02:54 AM | #6 | |
1750
Rep 17,960
Drives: A Lot
The twin scroll 6466 runs a big 1.0 hot side and makes full boost at 4500rpm. Peak HP at rev limit (7300rpm) with no signs of slowing down above that. Amazing power with a ridiculously wide powerband. More later |
07-27-2013, 02:58 AM | #7 | ||
Rep 1,392
07-27-2013, 02:59 AM | #8 |
Rep 1,392
07-27-2013, 03:07 AM | #9 | |
Rep 2,842
So is that stacked then? . |
07-27-2013, 03:13 AM | #10 |
1750
Rep 17,960
Drives: A Lot
07-27-2013, 04:19 AM | #12 |
Rep 330
Road raced, over-revved, neglected, and still kicking
This is sick. I need more oil coolers.
FFTEC 6466 6mt 335i | FFTEC GTX3076R Evo IX
07-27-2013, 04:30 AM | #13 | |
1750
Rep 17,960
Drives: A Lot
Shiv |
07-27-2013, 04:41 AM | #14 |
Rep 330
I'll get it to overheat. Trust me.
07-27-2013, 04:56 AM | #15 |
Rep 658
not impressive for this turbo
on race gas alone it should be making appox 750whp something is limiting this turbo whether it be the manifold or tuning or both lol whats the deal with only 22.5 psi on race gas you should be able to crank up the boost but can't tell without any logs. post some logs for a high compression motor with a 6466 this is kind of embarassing lol |
07-27-2013, 05:22 AM | #18 |
1750
Rep 17,960
Drives: A Lot
Pictures, datalogs and dyno graphs just added to first post
07-27-2013, 05:25 AM | #19 |
1750
Rep 17,960
Drives: A Lot
Been there, done that. Made over 600whp on 91oct with the single scroll 6466. The purpose of this tuning session was to make big power.
07-27-2013, 05:30 AM | #20 |
1750
Rep 17,960
Drives: A Lot
When meth isn't spraying, the Procede runs a more much more conservative ignition advance curve. Also, without meth spraying IATs are higher which means air density is lower. Both cause power losses far greater than the 2.5psi lower boost pressure would suggest.
07-27-2013, 05:31 AM | #21 | |
1750
Rep 17,960
Drives: A Lot
07-27-2013, 06:58 AM | #22 | |
Rep 571
can u tell us the difference between the 6466 single and twin scroll |
