30FE, boost pressure charger too high
07-27-2013, 08:37 PM | #1 |
Rep 659
******************* TURNS OUT THE PREVIOUS OWNER OF THE CAR HAD BYPASSED ONE OF THE BOOST SOLENOIDS**********************
Car goes into limp when pushing 3k+ rpm in 3/4/6 gear. Consistently pulling this 30FE code, what is causing this? I can hear what sounds like the waste gate rattling upon deceleration when the car goes into limp. No tune in car Last edited by vanondemand; 07-31-2013 at 03:27 PM.. |
07-27-2013, 10:12 PM | #3 |
Rep 659
07-27-2013, 10:32 PM | #5 |
Rep 659
07-27-2013, 10:44 PM | #6 |
Rep 6,136
07-27-2013, 10:47 PM | #7 |
Rep 659
07-28-2013, 05:31 PM | #9 |
Rep 1,677
Drives: 14' GMC Terrain SLT-2
I say your headed to the right direction. under CPO?
SOLD:: PTF Pro eTune by Dzenno / COBB S1+ E50 Alpina B3 Flash / ETS FMIC / ER CP / CPE DCI |
07-28-2013, 05:51 PM | #10 |
Rep 659
07-28-2013, 06:01 PM | #11 |
Stupid Idiot
134
Rep 827
The only things I can really think of that could cause this would be something with one of the boost-control solenoid valves , or mechanical jamming of the wastegate. Even then, usually it is a 30FF (boost too low) that is stored when the wastegates are mechanically jamming. I've never seen one cause overboost faults.
07-29-2013, 06:36 PM | #14 | |
3442
Rep 79,211
07-29-2013, 09:46 PM | #15 |
Rep 659
07-29-2013, 10:11 PM | #16 | |
Stupid Idiot
134
Rep 827
Unless someone removed/installed the cats in the past, the V-band shouldn't be in the way of the wastegate mechanism. The potential issues mentioned be me and the others are really the only things that could cause this. Now you need to do the legwork and figure out what it is. If you aren't comfortable doing these type of checks, you might want to take the car to someone who specializes in these cars for an opinion.
07-30-2013, 09:33 PM | #19 |
Stupid Idiot
134
Rep 827
I can send you a flowchart for vacuum readings at various points in the N54 turbo vacuum control system. It's pretty helpful in determining what the vacuum should be and when. PM me your email address if you're interested.
