mods by priority
07-30-2013, 06:27 AM | #5 |
Rep 4,088
You'll get a different answer from everyone. Case in point, I say (and did) LSD first. No point in making more power on these cars if you can't put it down in low gears, IMO.
The real question is, how do you intend to use the car and what's your driving style? if all you care about is smoking other cars on the fwy, then yeah sure get all the power adders you want. If you care an inkling about handling traction, then there's a LOT the chassis needs to be truly competent. |
07-30-2013, 07:58 AM | #7 |
DisplacementReplacement
440
Rep 1,131
Tune, OCC, DCI, FMIC, if you have an I then LSD, DP's, Meth if you want and then upgraded Turbo's. Don't forget some suspension work along the way. Good luck.
07-30-2013, 08:46 AM | #8 |
Rep 342
Drives: E90 Monaco Blue 335i xdrive
I noticed some of you put fmic after dp or not in the list at all. I personally think it's highly recommended after a tune and a dci or whatever intake you get.
2010 E90 335i xdrive | Monaco Blue with Black Interior | All Packages except Sport :/ | Apex EC-7 | Active Autowerke Strut Bar | Roc Euro DCI | Roc Euro Hyperboost DVs | aFe Scoops | BMW Performance Exhaust | BMWCCA member
07-30-2013, 10:44 AM | #9 |
Rep 6,136
07-30-2013, 10:45 AM | #10 |
3442
Rep 79,211
Tune>Intake>FMIC>Downpipe
Suspension somewhere in the middle. LSD if you got bank. The reality is the "proper" way to add power in this car would be to do all the power mods at once. You get the intake for the breathing of the tune. You got the FMIC to combat intake air temps which keeps the motor happier. You get the downpipes to reduce the back pressure. |
07-30-2013, 12:21 PM | #12 | |
Rep 886
Saying this makes me think that, rwd n54 is not good from the dig on public roads??? (i am awd and fbo)
Bmw 335xi/FBO/ black on black/ 6sp manual/Cobb AP/BMS DCI/AA BOV KIT/VRSF DP'S/VRSF 7'FMIC /FULLY CATLESS/H&R sport springs/ 19' ac schnitzer wheels.
07-30-2013, 12:30 PM | #13 |
Rep 4,088
Yeah it's probably more pronounced in RWD if you are talking about putting the power down effectively. But the handling issues over rough roads would be systemic to all non-M e9x's. It's the darned soft bushings - they are crap!
08-03-2013, 11:56 PM | #14 | |
Rep 164
08-04-2013, 12:04 AM | #15 | |
Rep 414
Thanks And sorry for the
"And just one question I might ask yah, and it might sound like A disaster, can you make this thing go faster?"
08-04-2013, 12:26 AM | #17 |
Rep 414
To stop the rear end from sliding around on itself?
08-04-2013, 02:30 AM | #18 |
Rep 561
i went DCI , DP, FMIC, Tune, then up next is exhaust, charge pipe, oil cooler, turbos, then LSD ... IMO its best to get the bolt ons out the way first, as to reduce the strain on the engine when a Tune is added
08-04-2013, 09:11 AM | #21 | |
Rep 1,945
Drives: 2011 335xi Msport, Conv, Tech
|11 335XI N55 | M SPORT | VRSF CP | BMW PE | BMS INSTAKE | VRSF 7" IC | MHD STAGE 2+ | ER CP |
08-04-2013, 11:45 AM | #22 |
Rep 5,463
Tune you can make use of without any other mods as you can run a light tune, so do that first, then you really need DCI, IC and DP's all at the same time when you dial up the tune, then exhaust etc after that.
2025 X5 Msport
