Powerless after I serviced my 335d
08-04-2013, 04:22 AM | #1 |
Rep 477
I serviced my own e92 335d, changed everything that needed to, an my turbo boost pipe, which is the big red hose, had all oil on it, so I thaught it may be leaking, so I spent time an managed to take it off and clean it an check the seals an hose itself which seemed fine :/.
Anyway after doing that and the service, I put the car on and drove it then I get this loud air type of noise coming from the engine when I put my foot on the accelerator, the noise sounds like a really loud version of air escaping from a tire. There is also a very bad power loss now an the car has no power along with this light coming on the dashboard (the one in the link which says "check") https://www.google.co.uk/search?q=e9...-E2DiQUMRTM%3A |
08-04-2013, 04:38 AM | #2 |
Rep 650
I would say check your boost hose again, it's obviously not seated correctly or seal has moved. It's the only thing you did yesterday and before that it was ok I presume? Recheck that hose and any other hose you had off aswell
08-04-2013, 06:05 AM | #3 |
Rep 2,048
as above I bet the boost hose has not been seated in properly, when you put the red boost pipe back on the clip/tab which attaches the end to the turbo did you hear it click into place?
