E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > annoying squeak
Reply
      08-12-2013, 02:08 PM   #1
afalton
Drives: bmw e92 330i m sport
annoying squeak
Evening everyone
My 2008 pre lci e92 330 sport has intermittently
Started squeaking I looked underneath and
checked Everything out that's visible and to nothing
Obvious
Also I have herd that the osr suspension is lower
Than the nsr As the lhd cars are set up and bmw
Didnt change this for rhd I read this on the forum
Somewhere
Thanks
      08-12-2013, 03:41 PM   #2
magic77
magic77's Avatar
Drives: ex- 335i
if its a squeek when going over slowly over speedbumps etc. It will be the bumpstops on the front suspension
Part 11 in pic
Want hurt to jack the car up as high as you can to expose it and clean it up with a rag then use plenty of copper grease on the top surface that rubs against the suspension plate. Also clean the suspension mount underside where it rubs.
Did that and also used some GT86 (water repellent, lubricant) to oil up the inside part as best as it can be without removing. Did this a while back since then no noises at all and it was a right old squeek
F30 335i M Sport - now departed
      08-12-2013, 04:25 PM   #3
afalton
Ah I see I'll have to try it thanks
What do u think of the suspension
level I noted?
      08-12-2013, 04:48 PM   #4
magic77
magic77's Avatar
Drives: ex- 335i
I cant say I noticed on mine driveway slopes in multiple directions so its always sitting on a funny angle. And with my small 120kg frame 95% in the car on my own I doubt the suspension ever sits level
The few times I've looked at it on near level ground it looks pretty much identical to me on both sites.
Only thing is to measure it and see as I recall this alteration for LHD cars being mentioned before
      08-12-2013, 05:06 PM   #5
afalton
Thanks mate I'm just paranoid as I don't like
Hearing odd noises
I'd have to look further into the rear suspension
Thanks again
      08-13-2013, 02:46 AM   #6
ukbeemerboy
Beemer Heaven
ukbeemerboy's Avatar
Drives: BMW M4 Competition
Originally Posted by afalton View Post
Evening everyone
Obvious
Somewhere
Thanks
The rear suspension on my E46 was lower on the off side and that was common, but my E90 is level.
Scott
2018 BMW M4 Competition
2019 Mini Countryman Cooper S : 2008 Mini Cooper
      08-13-2013, 02:56 AM   #7
phil200tdi
phil200tdi's Avatar
Drives: 335i M Sport E90 LCI manual
Evening everyone
Obvious
Somewhere
Thanks
If it squeeks and rattles going down a rough road, spray silicon lubricant on all the door seals. I did this last weekend and its unbelievable how much difference it made - now silent in the same situation.
Car: e91 330d with Viezu map
Gone but not forgotten: 2010 Jaguar XFR (Cat-back exhaust, pulley, intake mods and map), Highly Modified E90 335i LCI M Sport Manual (circa 480BHP/500lb ft)
      08-13-2013, 05:08 AM   #8
afalton
Thanks guys I'll have to try fingers crossed
      08-14-2013, 07:45 AM   #9
Terryk
Terryk's Avatar
Drives: F30 mineral grey N47 ed
for door sealants etc better use the product called gummi pflege (it's from 1Z detailing products series)
Reply
e90post
