BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > F20 Brake Disc Rusting 2 Months of Ownership
      08-18-2013, 10:49 AM   #1
E60MKF
Drives: BMW F10 MY2013
I've had my F20 since late June (May build). I noticed last month the brake disc on one wheel was rusting. I took some pictures today, what should I do? I am very annoyed at this if I'm being honest.
All and any advice is appreciated!
Thanks
BMW E60 MY2008 (LCI) 2007-2013
BMW F10 MY2013 2013-2017
BMW F20 MY2013 2013-2016
BMW F30 MY2014 2014-2015
      08-18-2013, 11:09 AM   #2
Bradbury
Vroooooom!
Bradbury's Avatar
Norway
Drives: F20 120d
Go for a two-minute drive. As long as you use the brake a couple of times, the rust will go away.
      08-18-2013, 11:16 AM   #3
E60MKF
This is after the car had gone on a 10/20 minute drive (son is learning how to drive).
      08-18-2013, 11:37 AM   #4
ovekvam
Norway
266
Drives: 2021 Galvanic Gold i3S
I think the brakes on all cars look like that after being left overnight with wet brakes. If it doesn't go away immediately when you drive the car, maybe your son is too careful with the brake pedal?
      08-18-2013, 11:44 AM   #5
orcomma
Dividing by zero
orcomma's Avatar
Drives: F48 X1 XDrive20d xLine
I've never had a car where there discs stay shiny all the time!
      08-18-2013, 12:21 PM   #6
E60MKF
I've never seen this until this car. I'm guessing its fine then?
thanks
      08-18-2013, 12:30 PM   #7
pron
Drives: 125i M sport
Just take a few hard stops (with 4 people in the car), and it will go away. It is often on the rear breaks this is necessary.
      08-18-2013, 03:20 PM   #8
Bob UK
Drives: 2013 X1 18d X-Drive
It's perfectly normal, discs are ferrous metal and the fresh surface revealed after braking will oxidise very quickly when wet.
Washing my car takes me around 1.5 hours including drying and if the discs were shiny when I started, by the time I'm done they are brown, it's that quick.
120d Sport gone and replaced with X1 18d XDrive MSport Auto.
No Xenons but plenty of creature comforts.
      08-18-2013, 04:35 PM   #9
SpokenHands
Certified Car Nut
SpokenHands's Avatar
Drives: AMG GTC + RR Velar + 640d GC
Brake disc rust is absolutely normal, will brush off under normal braking.
What annoys me is the rusting around the brake rotors and callipers, both do not have any discernible effect on the function, but they're not seen as cosmetic parts so BMW doesn't consider it an issue. This is not BMW specific.
      08-18-2013, 05:10 PM   #10
pangster
Scotland
Drives: F20 M135i LCI
LOL! - sounds like you're the kind of person who puts tyre shine on the treads as well!
this happens on ALL cars.. (unless you have carbon ceramic brakes...)
      08-18-2013, 06:39 PM   #11
pacoluca
pacoluca's Avatar
Australia
Drives: BMW 125i M Sport
yes, it's very normal after the car wash and when you haven't driven the car for a while in a moist environment. That's why it's good practice to take the car for a 5-10 mins spin with some hard braking to get rid of the water and moisture sitting on the brake parts after car wash.
      08-19-2013, 02:08 PM   #12
EdenH
Drives: F21 116i M Sport
My car is 5 months old and I was annoyed that it had started to rust on the hubs/caliper area, a can of hammerite sorted it out nicely
      08-19-2013, 03:20 PM   #13
E60MKF
if thats what I did, then my alloys wouldn't be filthy
      08-20-2013, 11:47 AM   #14
Bob UK
Get some wheel sealer on there, dirt sticks less and it just about hoses off.
      10-29-2013, 03:32 PM   #15
bchase86
Drives: 2012 135i
I had a N54 135 and when the lease was up I got an F20 135, have not changed anything and over the first winter of having the F20 under the car cover the rotors rusted and made it feel like they were warped when braking. Took it to BMW and they told me that it was environmental and not covered under warrantee and it would be $1700 for all new pads and rotors. The N54 sat in the same spot for 3 winters without this happening, so keep an eye on it.
I had the F20 rotors put on the lathe at a BMW dealer to not spend $1700 and in the past 3 months the rotors now feel warped again.
I'm going to try and get them to replace them now because I haven't let it sit for more than a day and was told the rust build up was from it sitting for more than 2 weeks without being driven.
Just letting people know and to see if other have had this problem as I see the 135 as a fun car not a daily driver altho it could be.
Thanks
      10-29-2013, 03:48 PM   #16
ovekvam
Norway
266
All the cars I have owned have had rusty brakes if I leave the car overnight with wet brake rotors. It takes one hard braking to remove the surface rust.
Rotors actually becoming warped is very rare. When they appear to be warped, it is usually buildup of brake pad material. This can typically be removed by running a brake pad bedding procedure.
      10-30-2013, 05:34 AM   #17
Bob UK
Warping is more likely if you are in the habit of staying on the footbrake after coming to a stop. The pads in contact with the friction surface creates a hot spot and over time any weak points in the disc get stressed and the disc will deform.
Something I was thinking about whilst driving an auto loaner, I found myself sitting on the brake quite a bit in urban driving. I suppose it's not as much of a risk due to the low speeds but still can't be good for the discs long term.
      10-30-2013, 06:35 AM   #18
ovekvam
Norway
266
In this situation, you will typically also get som pad deposit on the rotor, often visible as an imprint shaped like the outline of the brake pad.
      10-30-2013, 06:00 PM   #19
orcomma
Dividing by zero
orcomma's Avatar
Same here - as a manual owner, I recently had an auto courtesy 3 series, and I also couldn't help thinking about how dazzling for the people behind it must be with the LED brake lights constantly on in a queue. Must be awful in the US where most cars are autos.
Then again I also still can't get my head round the electronic handbrakes in Audis - if the power fails does the brake fail-on or fail-off? if it's parked on a hill and the battery dies does it roll down hill? or is it just impossible to bump start it or drag it onto a low loader.
The Night Project - X1 20D xDrive xLine - Black Sapphire, Sun Protection Glass, 19" 511 wheels powder coated in high gloss black, Shadowline trim, MPerformance grilles.
      10-31-2013, 05:52 AM   #20
Bob UK
Electronic handbrakes are generally universally hated from what I can gather. Reporting your car stolen only to find the EHB failed and it had rolled away could be a bit embarassing.
1addicts
