BIMMERPOST Universal Forums Off-Topic Discussions Board Does Aviation Gas have lead?
      10-04-2007, 11:56 PM   #1
midlife
ocasionally in crisis
midlife's Avatar
55
Drives: '08 335i cabrio
i read in some forums that aviation gas has lead. and that adding it to car gas (to boost octane is a no no (because of the lead).
i am now being told here in quito ecuador, that the aviation gas here DOES NOT have lead. since planes fly into countries all over the world, there must be an international standard of aviation gas that says if lead IS or IS NOT in aviation gas.
i know about most all of the ways to boost octane, but aviation gas here in ecuador definitely has it's advantages.
SOMEONE IN THIS FORUM MUST KNOW THE ANSWER TO THIS SIMPLE QUESTION.:help:
thanks
      10-05-2007, 12:07 AM   #2
RedGT3
RedGT3's Avatar
Drives: .2 GT3/M3cs
Aviation fuel in the states has lead 100LL.
      10-05-2007, 12:14 AM   #3
myfirstbimmer
Drives: E90 SG 330i
All AVGAS, 100LL has lead. A big nono to carburated engine in cars. Dont do it. 100LL = Low Lead.
In my past flight training, AVGAS and MOGAS don't mix, even certain avaiation engines can use MOGAS (car gas) as substitues, the detontation properties aren't as good as the commonly used 100LL. Either way, no way to put 100LL in your bimmer unless you like to experiment with a repair bill.... where you live, Ecuador, it is possible that you see other AVGAS available, that is below 100LL catagories. But most of the airports now only carries 100LL. Anything above 100LL will be JetA.
35% Formula 1 Ceramic Tints, //M E-Brake handle, //M Steering Wheel
      10-05-2007, 08:52 AM   #4
777ER
777ER's Avatar
Drives: 2007 328xi
There's 3 different AVGAS:
Red dye colored: 80 octane
Green dye color: 100 octane
Blue colored: 100 octane low lead (AKA 100LL)
Jet A is kerosene with additives to combat microgrowth and ice crystals in the fuel. Octane rating comes out to somewhere like 40-48 if used in a piston engine.
Jet B is the same as above but can withstand freezing temps better and often the military uses it.
-Chris
2007 Montego Blue 328xi
Sedan | Poplar trim | Steptronic | Cold Package | Power front seats w/memory | Xenon Adaptive Headlights | PDC | 2008 Plate LED's | PBX | LUX v5.2
      10-05-2007, 09:01 AM   #5
boostedbavarian
boostedbavarian's Avatar
Germany
119
Drives: to many cars too fast
ive been running vp racing c16 leaded fuel in my subaru for over a year, but i do have different rails and fuel lines and i did have to replace my o2 sensor once($150.00) but other then that no problems..
________
Michigan Marijuana Dispensaries
________
TEEN GIRL LIVE
________
California Medical Marijuana Dispensary
________
Laguna Heights Condo Pattaya
      10-07-2007, 01:03 PM   #6
midlife
midlife's Avatar
55
do you run the leaded fuel every day in a daily driver, OR is it a track car?
your different fuel lines, understood. but what are RAILS ?
also, you think your gas TANK will be O.K. in a few years ?
how hard would it be to replace an o2 sensors in a 335? and what were the symptoms that told u the o2 sensor needed to be replaced?
most interested.
thanks
______________________________
2008 335i cabrio: expecting Oct 15 !!
1968 396 Chevelle SS convertible
(rebuilt from the ground up)
’95 540i retired
’94 M3 retired
’81 911 Carerra retired
      10-11-2007, 08:34 AM   #7
Rossland
Drives: US 06 330xi
777ER knows his stuff. If you have a diesel you can burn jet fuel, but otherwise stay away from avgas. The lead will ruin the catalytic converter and foul the plugs and valves
      10-11-2007, 08:43 AM   #8
boostedbavarian
Germany
119
most interested.
thanks
?95 540i retired
?94 M3 retired
?81 911 Carerra retired
well i have dif fuel rails bc i switched from side feed to top feed injectors, my car constantly has it in it, but its not a daily driver and i def wouldnt recomend c16 for a dd if you have a high hp car i would not recomend tunning over non leaded 100oct other then that its basically a non dd and even 100oct gets very expensive, so honestly stick to pump 93 with a 100oct map, about my gas tank honestly i really dont know only time will tell for me so i know there is a reaction for every action i take, 02 sensors arent that hard to replace they are just sensors in the downpipe, also remember i dont have cats, so leaded fuel will eat right thru them..
________
Honda n360 specifications
________
Avandia Death
________
Washington dispensaries
________
WEB SHOWS
