Saw this under the hood..
08-27-2013, 11:00 PM | #1 |
Rep 888
It appears it's a little bit of oil. You can see on the plastic where it's darker. I had this before, wiped it away to see if it was just a little bit of oil that spilled, but now it's back. Is this normal? What could it be?
08-28-2013, 05:01 AM | #2 |
Rep 18,823
I'd guess a leaking oil filter housing gasket is the source of the oil. When you are driving there is a lot of air turbulence under the hood. The OFH gasket has a small leak, the turbulent air picks up the oil vapor and deposits it on the air filter housing.
08-28-2013, 10:44 AM | #3 |
Rep 888
Wow thanks for the reply. I also had it in the back part of the engine cover as well, so your guess sounds spot on. What do I have to do to fix it? Thanks again!
08-28-2013, 02:38 PM | #5 |
Rep 6,478
I’ve never seen oil there, that’s an odd spot…There’s no oil flowing near the air box, so the only thing I can think of is oil depositing there somehow…But even then, it’s pretty centralized, looks like a classic “leak”. I’d take the box off and give the engine bay a good look over, see if you can find oil elsewhere.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
08-28-2013, 08:20 PM | #6 |
Rep 18,823
08-28-2013, 09:58 PM | #7 | |
Rep 888
08-28-2013, 10:33 PM | #9 |
Rep 6,478
I meant more along the lines of take the airbox off of the car and see if anything underneath or around has oil on it. If it's just isolated to the airbox, i'm baffled.
08-29-2013, 02:16 AM | #10 |
Gateropode
329
Rep 2,846
Do you see your oil level decrease ? Could be a turbo leak getting oil inside the airbox. Best action there is to open the airbox and see what's in there. Should be dry.
