White Smoke... PCV? Burning Oil? HELP
09-10-2013, 03:10 PM | #1 |
Rep 4,393
It seems like the issues really never stop... Basically here's what happened. I updated my JB4 to firmware that Terry wanted me to try to get rid of my rattle and it worked. I took it on a test drive and was ridiculously happy, hadn't heard pure turbo spool in months.
Anyways I continue driving light throttle to listen for rattle and start to feel a rumble like a misfire. I decide to turn autoclear off and go WOT so I can see which cylinder is misfiring. I do it then get my SES light and put the car in neutral. The RPM's drop to around 2k and it seems like the car is about to die and it's making a revving sound if I remember correctly. So I shut it off for a few seconds like normal. When I turn it back on SES light is still there and it's rough but i'm in the middle of the road so I accelerate lightly. Look back in my rearview and see a huge cloud of what looked to me like pure white smoke covering the road. Almost took a picture but by the time I got my phone out I was too far away. After traveling 100 yards the SES light was gone and it was back to running smooth so I could get home. Checked codes and it was cylinder 4 misfire. Yesterday was cylinder 5. I changed spark plugs about 8k ago, coil packs few weeks ago, and now have all bank 2 injectors waiting to be installed as soon as I can. My only problem is now with this white smoke i'm extremely worried. Any ideas...? My car has around 59.5k miles on it. I also checked oil level on the nav and noticed it's getting kinda low (see pic below). Oil was changed at 53k. It really does seem like it never ends with this car
< Click picture for photoshoot
E90 335i xDrive 6spd, Nav, Prem, Cold Weather, & Sports package - Msport Conversion Mods: JB4 + MHD, Doc Race ST, Pure 6266, AD-Eng PI/Mounts, Fuel-It st. 3, Custom Exhaust, Tuned by TwistedTuning More Pictures: Build Thread /// 683AWHP/675AWTQ |
09-10-2013, 03:23 PM | #2 |
Rep 6,478
Lol maybe 25% of the N54s on this forum are currently running with zero issues I’d wager. It’s a finicky gal. Try to figure out what leads to smoking- does it happen under vacuum? The PCV system could be blowing oil through to the rear inlet, then burning that off, certainly plausible. Could be a turbo seal on the way out, if it smokes under vacuum I would start to lean in that direction. But as you know, there are numerous other things that do a crap job of holding oil. VC gasket, OFH gasket, list goes on and on. These motors are such crap when it comes to controlling oil. I’m probably going to pony up for RBs in the next week or so, at least one of the turbo bank’s seals has got to be shot. And I think my VC gasket is leaking based on the oil I saw on plug threads but not on the electrodes….Fun times w/ N54s.
Edit: didn’t realize- you should nail down that it is indeed oil burning, and not coolant. The smell will give it away, burning oil truly smells like….well burning oil. Coolant has a syrupy and sweet smell.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
09-10-2013, 08:10 PM | #3 | |
Rep 4,393
09-11-2013, 09:19 PM | #4 |
Rep 83
Injector
If this happens only. With the new map there is something wrong with the map. The problem is an injector is hanging open causing fuel to leak into the cylinder resulting in the white smoke. On these engines white smoke = fuel.
09-11-2013, 09:23 PM | #6 | |
Rep 4,393
09-11-2013, 09:33 PM | #8 |
Rep 4,393
Yea i'm sure these injectors are all failing. Hopefully the swap fixes it
09-11-2013, 10:21 PM | #10 |
Rep 4,393
I know the shop that installs them will code them afterwards
09-12-2013, 12:26 PM | #12 | |
Rep 4,393
09-12-2013, 12:43 PM | #13 |
Rep 6,478
It would be obvious if coolant. Between the smell and the fluid loss (you'd likely get a low coolant warning if it was burning off over a period of say weeks), would be clear.
Based on what you're experiencing, i'd lean more towards oil burn or possibly fuel burn. Or both! lol.
09-12-2013, 10:34 PM | #14 |
Rep 363
Damn man that sucks, hope you get it sorted quickly. My car also developed long cranks and wastegate rattle after I got back from bimmerstock. Also threw a half CEL. Adjusted WG and all is well (for) now.
I feel like the more you "mod" these cars the more issues you get. Been running stock for months no issues, throw in a tune and a week later all this junk pops up. But I guess you gotta pay to play right? Smh! |
09-12-2013, 10:53 PM | #15 | ||
Rep 4,393
09-27-2013, 07:24 AM | #16 |
Rep 8
Thought I'd throw in my two cents... I'm just about ready to roll 59k on my 335 and this last week I've had long cranks and rough idle when starting the car in the morning. Each morning it got worse and finally got to the point yesterday where it would start but sounded like a Harley and was blowing huge clouds of pure white smoke. I couldn't drive it so I had to have it towed. This morning as I was reading this thread, my SA called to let me know that I was getting new injectors, plugs and an oil change. Man, I'm glad I went CPO...
09-27-2013, 10:17 AM | #17 | |
Rep 4,393
09-27-2013, 10:29 AM | #18 | |
Rep 6,478
09-27-2013, 10:37 AM | #19 |
Rep 4,393
Yea it is bizzare... I'm planning on doing vc gasket whenever i can. Already have a new pcv hose and might do the rb valve too while i'm at it
09-27-2013, 11:20 AM | #20 |
Rep 6,478
I would strongly rec you just overhaul the entire PCV system with Rob’s valve and cover. A new check valve can help, but there are fundamental flaws that only RB’s solutions remedy. If you’re comfortable removing one fuel rail for space, it’s a pretty simple install. Actually only annoying part is getting the PCV cover to re-thread, for whatever reason it doesn’t want to go back on.
09-27-2013, 12:22 PM | #21 | |
Rep 4,393
