E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > 335is overboost feature
Reply
      09-16-2013, 05:19 PM   #1
Briancanadiano
Brian335tt
Briancanadiano's Avatar
Drives: BMW 335i premium package 19"ri
So this might sound like a stupid question but I was curious if it was possible to get the over boost function that the 335is has where in the first 7 seconds hits 370ft/tq on take off.. I was wondering is this possible to get on a regular 2007 335i coupe? Will the jb4 g5 give me this feeling? Thanks
      09-16-2013, 05:28 PM   #2
CHECKERED
ex deus machina
CHECKERED's Avatar
Drives: G30, F15, Audi S4
why do you only want the extra boost the first 7 seconds, why not always?
Daily: G30 M550i, Bluestone, JB4, 1 step colder plugs, 6WB retrofit
Winter Beast: Audi S4 4.2L V8, Supercharger, brakes, suspension & exhaust mods
Wifes': F15 M50d clone, DUDMD tune, WMI, MPBK
Gone: E92 335i N54 468rwtq
      09-16-2013, 06:47 PM   #3
blacknbean
Drives: e92 335i 6MT
ya, any tune will give you unlimited "overboot"
      09-16-2013, 07:08 PM   #4
Briancanadiano
Brian335tt
Well I want it all the time, my question is, will it give me that sudden take off like the 335is? I do have an auto tranny donno if that matters.. And the 335is in order to get the over boost function they added crazy air vents and fans and all that stuff to help cool it down since its runnin all that boost. Wouldn't I need all that stuff to? In order to be safe enough to handle the tune... Thanks for your input guys.
      09-16-2013, 07:31 PM   #5
Eleventeen
Drives: G42 M240i
JB4 or Procede will give you that much power or more full time. No other parts necessary.
      09-16-2013, 08:14 PM   #6
TurboSid
TurboSid's Avatar
1114
Drives: 2022 M4Cx BSM/FR
2008 335i  [0.00]
Just get a power kit for the other added benefits that a 335is has
2022 BSM/FR M4 Competition X-Drive
2017 MW/SO M4 ZCP [SOLD] • 2015 MW/SO M4 M-DCT FBO [SOLD] • 2011 AW/CR 335is DCT FBO [SOLD] • 2008 AW/CR 335i 6MT FBO [SOLD]
      09-16-2013, 11:45 PM   #7
BEAR-AvHistory
2020 Z4 M40i - 2022 M4C Convt
BEAR-AvHistory's Avatar
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Power kit is not the same software. The 335is has different base software with a different ignition curve more suitable to higher boost.
My 135is runs the PPK-2 power kit as factory standard & stock for stock the 335is is stronger.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers
2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT
      09-17-2013, 05:22 AM   #8
Briancanadiano
Brian335tt
This is what I'm talking about.. Wouldn't it be possible to use the 335is software on a 335i? Given in practically a factory tune that is probably considered the safest out there
      09-17-2013, 06:23 AM   #9
farbmw
farbmw's Avatar
Trinidad_and_tobago
423
Drives: 2015 M4 6SPD MANUAL!
Yes, you can if you have a Cobb PTF @Dzenno and @Jake they can make a map just for that, and I am sure Terry must have a map that simulates it as well.
And the extra cooling features on my 335is, isn't just for the over boost, it also takes care of other things as well.
Have BT Tool professional, will scan and clear codes on your BMW. And now I am able to code my 2011 335is and M4
Link to my M4 euro delivery! http://f80.bimmerpost.com/forums/sho....php?t=1006526
      09-17-2013, 08:06 AM   #10
Briancanadiano
Brian335tt
Ya I feel that if I do the tune and don't have those cooling features it might be bad for the car, what exactly are the cooling features you speak about?
      09-17-2013, 08:18 AM   #11
farbmw
farbmw's Avatar
Trinidad_and_tobago
423
The 335is has the better far for the rad (850 watts), the two coolers in both wheel wells, cooling vents, software to control it and Ivo found some more differences but I can't remember what they were. I also had the AR oil cooler on my old 335i and it did make a difference in the temp, but since the 335is has two of them I sold it.
      09-17-2013, 08:56 AM   #12
Transport3r
Transport3r's Avatar
86
Drives: 2011 N55 E90
Running a tune isn't bad for the car, as long a s you run a good, well-tested tune. Shiv's car has been tuned since he bought it and now has 700+HP to the wheels, And I think he's over 100K miles now...
Josh-
      09-17-2013, 09:09 AM   #13
ttbmer
Drives: space gray on black 07 335i
true but it doenst mean hes never had a problem and when he does have one he made the tune software/hardware he can easily fix it unlike most if us reaching out 4 help for the most part.
can anyone list the mechanical differences between 335i and 335is other than the exterior Mtech kit or the obvious?
PROCEDE, PWM Vishnu Kit, AR catless DP, BMS DCI, Helix IC, P3 gauge, 25% window tint, mattblack window trim, mattblack roof wrapped. Vorstainer CSL trunk, CF wrapped interior, 18'' Forgestar F14 Matt black, quaife LSD, M3 suspension bits, Mtech front bumper). http://www.youtube.com/watch?v=b8JIB8C8HDA
      09-17-2013, 09:15 AM   #14
Transport3r
86
I think engine wise it has a better radiator, bigger oil cooler, and stiffer engine mounts.
Josh-
      09-17-2013, 09:19 AM   #15
yomny
yomny's Avatar
Drives: '13 335is 6spd
The car has a heavy duty radiator fan for improved cooling, an additional smaller radiator on the drivers side front air dam(replacing fog lamps) and the improved oil cooler on the passenger side. Aside from that, the tune which as mentioned above is improved in all aspects, not just an over boost function.
To answer the initial question, the only way to get the function of the 335is is to tune your 335i but it wont ever have a temporary over boost function, that's only bmw's software, I could be wrong. You could get a tune and improve timing and air fuel along with more boost. I think bmw has proven that its safe and reliable to run 14 psi on these cars all day given that cooling is sufficient.
      09-17-2013, 09:48 AM   #16
shortseller
shortseller's Avatar
Drives: ‘18 ABM F80ZCP/dct
I think that is correct. they basically took a page out of the Dinan tune handbook based on their stage 3 tune data history, running at 14psi w/ ancillary OC, IC and exhaust. Pull on it all day w/o worries.
      09-17-2013, 10:23 AM   #17
BEAR-AvHistory
I don't think so. Terry's firmware takes advantage of the factory software does not replace it. He runs two different firmware versions for the 335i & 335IS
Kevin
      09-17-2013, 10:59 AM   #18
Briancanadiano
Brian335tt
So if I get a better intercooler and a better oil cooler, and get a mtech front bumper do the fog delete for vents then I'm ok?
      09-17-2013, 11:39 AM   #19
Transport3r
86
you don't even need the bumper, even just an oil cooler would be fine, but then again I wouldn't advise anyone against upgrading the FMIC. The stock unit is garbage compared to even the cheap aftermarket offerings.
Josh-
      09-17-2013, 12:48 PM   #20
ttbmer
so the mark up 4 335is is just on the cooling and cosmetic looks?
      09-17-2013, 12:57 PM   #21
Transport3r
86
Yes, and the DCT if you're into that kinda thing.
People who own one will of course tell you it's the rarest type of E92/93 but how much does that matter IDK, still a mass produced model..
Josh-
      09-17-2013, 01:37 PM   #22
bwco
Drives: 535i xDrive
what makes the stock unit such a piece of garbage?
Reply
e90post
