How to launch 335 6mt Procede??
10-11-2007, 02:40 PM | #1 |
Rep 155
I'm going to the drag strip tomorrow and need some tips on how to launch my e92 6mt with procede. I have stock RFT and my only engine mod is the procede. Launching rpms, shifting rpms, tire pressures, etc.??? any tips will help.
Thanks in advance. Danny |
10-11-2007, 03:40 PM | #2 |
Rep 10,587
Hey, I just did that for the 1st time Monday. For Monday the weather was about as bad as it gets....mid 90s and humid w/ track temps around 96/97.
Here is my insight: Launch rpm - I was pumping the rpms up and down to keep boost up and launching at around 3000rpms w/ a slightly slipping clutch while feeding on the power. Its a delicate dance w/ the stock RFT to get good 60 ft times. The best I managed was a 2.0x 60 ft which I think it damned good w/ the RFT. Tire pressure wont make a lick of difference IMO w/ the RFT, the sidewalls are too stiff to allow a larger contact patch. They are designed to run w/ 0 psi afterall. From there, I shifted as quick as possible into 2nd at around 6500rpms, letting off the gas for a split second for the shift. 3rd and 4th gear I shifted around 6300rpms and did not let off the gas at all....kept it to the floor. I was fast enough that the rpms did not bounce the rev limiter at all resulting in good shifts. Make sure to post a report of how it went either here or in the forced induction/335 forum. here is a video of my best run against a slightly tuned E46 M3 Goodluck! Matt
10-15-2007, 06:34 PM | #4 |
Rep 155
sorry it took so long
Ok, heres the results
Atlanta Drayway elevation: 1002 ft. weather: about 65 degrees mods: Procede 1.47 tires: stock RFT here's my best slip r/t .571 60 2.299 330 5.907 1/8 8.868 mph 84.05 1000 11.374 1/4 13.496 mph 105.23 not the best times i guess but i couldn't get traction if my life depended on it. i would spin all of 1st and most of 2nd. Damn RFT. With a good set of tires I think I could've bought my time down atleast 2/10th of a second or more. Danny |
10-15-2007, 08:28 PM | #5 | |
Rep 8,327
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
10-15-2007, 08:34 PM | #6 |
ASR Turbos+LSD+Meth= :D
73
Rep 1,517
Drives: E92 335i
no, the best R/T possible is a .500 (unless you're racing funny cars and cars of that calibur... where the tree goes top yellow, striaght to green) ... so his .571 is damn good, thats seventy-one one-thousenths of a second off perfect...
Although i would expect a littler better from the procede... getting a .571 it sounds like you know what you're doing and can drive a track well... i had gotten a 13.077 @ 107 mph with a SSTT of course on RFT's aswell.
2007 335i Coupe Mods: Check the Garage |
10-15-2007, 08:54 PM | #7 | |
Rep 155
Danny |
10-17-2007, 01:42 PM | #9 |
73
Rep 1,517
Drives: E92 335i
when do you's guy's drag strips close? mine closes at the end of this month... i should have my dp's in and installed but im worried i wont and wont get to do a pass with them on =(
10-17-2007, 05:59 PM | #10 |
Rep 155
10-17-2007, 06:00 PM | #11 |
Rep 155
10-29-2007, 12:23 PM | #13 |
73
Rep 1,517
Drives: E92 335i
off completly, so i gets the yellow traingle and circle
10-29-2007, 03:01 PM | #14 |
Rep 101
10-29-2007, 06:04 PM | #15 |
73
Rep 1,517
Drives: E92 335i
i rev to about 1900, any more i find on the track and you sit spinning. but on the street you can go to like 2700 and launch well.
11-12-2007, 08:47 PM | #16 |
Rep 10,858
With good tires and an LSD, use the handbrake to build boost, and let it rip. Just make sure that you have the thumb button all the way in and that you get the handle all the way down!
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
11-13-2007, 12:54 PM | #17 |
The Tarmac Terrorist
951
Rep 29,345
Drives: 997.2 GT3
i am Stock, and i have found having it half de-activated works best, fully de-activatd = lots of smoke
997.2 GT3
