DSC coding issues at Dealer...
09-20-2013, 02:08 PM | #1 |
Rep 135
Hi All, My 335i has suffered the dreaded DSC/ABS/DBC failure.
The dealer hasn't been able to code the DSC module due to my retrofitted CIC. In order to code the car therefore, the CCC needs to be dropped back in so that everything can be "seen" The question is, is it good enough just to reconnect the CCC or do I need to re-instate the old CCC screen too? I hope the answer is just the CCC!!! Thanks John
Past Previous: E92 335i, CIC retrofit, JB+, Perf Exhaust Last Car: MB ML350CDI, X800D-ML Retrofit, AMG Steering wheel, Brabus tuning box Current car: F31 335d - NBT EVO ID6 retrofit, 3AG retrofit, Coded EBT, Deleted RFTs!! |
09-20-2013, 02:28 PM | #2 |
Rep 9,097
Complete CCC needs to go in.
Bmw upgrade system is pathetic and requires all the factory fitted parts. If your car is under warranty, then worth of going to the dealer otherwise go to your indy.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
09-20-2013, 03:04 PM | #3 |
Rep 5,050
I have the same problem with the simple install of a Dension 500s which installs on the optical loop. As I understand it, the BMW equipment scans the loop & if it finds anything wrong, or sees anything it doesn't expect, then it simply stops & won't proceed until the problem (or what it sees as a problem) is fixed.
Autologic on the other hand scans everything & accepts whatever is there & only complains if there's a real problem. It's ridiculous that simple add ons can cause the BMW system such problems & customers such big headaches |
09-21-2013, 01:28 AM | #4 |
Rep 135
Damn... Let's hope I can persuade Sytner to let me go and swap out the CIC screen myself!! I think they're going to be v confused.
Annoyed with myself, as completely forgot the hydro unit would be replaced with ECU and all. Thanks both, will call them first thing Monday and try for an hours "alone time" with the car!!! Last edited by jozza66; 09-21-2013 at 01:53 AM.. Reason: Spelling! |
09-22-2013, 11:03 AM | #5 |
Rep 109
What would happen if i were to come across such problems after i install cic from a non idrive system?
09-22-2013, 11:07 AM | #6 | |
Rep 9,097
Or take the car to local indy. BMW can't refused your claim as CIC was installed.
09-22-2013, 12:03 PM | #7 |
Rep 5,050
So don't flog your old bits
If I have the Business Nav upgraded to Pro would it just be a matter of slotting the the Pro radio unit out & slotting the old Business back, or would ALL the parts need to be reverted back to original? The Vauxhall system was similarly painful, the clock in the car could only be adjusted via the OE radio, so twice a year, when the clocks changed, I had to swap back, just to set the clock |
09-22-2013, 03:11 PM | #8 |
Rep 135
Wise words, and fortunately the old kit has been lying in a box int he cupboard, heading to Sytner first thing, for what I hope will be a world record breaking time for CIC to CCC downgrade
09-22-2013, 03:53 PM | #9 | |
Rep 9,097
Answer according to my best knowledge. Upgrade: 1- business CCC ---> Professional CCC = you can have permanent changes to your car's specs as BMW support that as a retrofit kit. 2- business CIC ---> Professional CIC = same as above. 3- business / professional CCC ----> business / professional CIC= You will have to put the original stuff back as dealer may not be able to code single module. However their advance technicians (in Germany) can do it over the internet. 4- Radio ---> CIC retrofit = Best to put the radio back in if its going for flashing and coding. If its just a routine service, then there is no need to put the original radio in. HTH.
09-23-2013, 10:34 AM | #10 | |
Rep 5,050
09-23-2013, 11:20 AM | #11 | ||
Rep 9,097
Your car will be coded to show that professional navigation was fitted in your car. However if you are over cautious, then you don't go for the upgrade or if you do, then keep your original navigation with you.
09-23-2013, 11:28 AM | #12 | |
Rep 5,050
S606A: NAVIGATION SYSTEM BUSINESS S612A: BMW ASSIST S615A: EXTENDED BMW ONLINE INFORMATION S616A: BMW ONLINE S633A: PREPARATION, MOBILE PHONE, BUSINESS S694A: PROVISIONS FOR BMW 6 CD CHANGER S698A: AREA-CODE 2 FOR DVD S6AAA: BMW TELESERVICES S6ABA: CONTROL, TELESERVICES S6VCA: CONTROL, COMBOX I'm guessing that my Sat Nav must be "Business CIC" so '2' above should apply, so does that mean that if I upgrade to Pro the BMW system will just ignore it? Can I also have connected drive services etc just the same? Cheers |
09-23-2013, 11:30 AM | #13 | |
Rep 5,050
I'm definitely in the market for an upgrade them - I'd just hang onto the business stuff, just in case, cheers |
09-23-2013, 11:34 AM | #14 |
Rep 9,097
If you have working internet, then just adding a CIC into your car.
Experienced person will take out the business nav out of your car settings and save professional navigation into the car settings. HTH.
09-23-2013, 11:44 AM | #15 | |
Rep 5,050
pm sent |
