Akrapovic +rear cats delete = disaster
09-26-2013, 01:42 AM | #1 |
Rep 589
So
I have the aa catless dp' And the akrapovic muffler Unfortunately its little quiet then the stock So I removed the secondary cats (straight pipes insted) I ended with a lot of smoke in the first 10 min of driving (only when cold start) And nice sound Also I have a metal ticking sound that appear at 1500-1700 rpm when I press 20% of the pedal like something vibrating at the middle to back of the car I can hear it on higher gear slow speed when it building pressure I go to few guys to check it And everyone said something else "U need to put back the secondary cats " " u need replace the pipes because the pipes instead the secondary cats maybe vibrating or too thin " Anyway I thought I bought the best axle back in the market And I have this f*****g sound (only when I'm not floor the pedal) I don't know what to do more Thinking to get the rear cats back and end it. Can someone advise Also I miss the stock muffler it has that pop pop crackle sound.....
2008 e92 335 FBO
2011 e92 M3 ZCP DCT 2015 f82 M4 DCT |
09-26-2013, 03:41 AM | #3 |
Rep 589
Where ????
2008 e92 335 FBO
09-26-2013, 10:10 AM | #6 |
Rep 589
U sure?!
And what Install Tham where the secondary cats was?
2008 e92 335 FBO
09-26-2013, 10:31 AM | #7 |
Rep 280
09-26-2013, 11:57 AM | #8 |
Rep 1,099
I think the smoke your seeing is because your catless and its the gunk burning off or something while ur cars getting warmed up. The metal ticking sound is probably from your wastegates..the wastegate rattle is supposed to be more audible with catless downpipes but nothing wrong with that. if you have a tune (like jb4) you can change some settings to help get rid of that sound. If the sound is too raspy for you then get the resonators described above
