OpenFlash Tablet E40 OTS update (Dyno)
10-04-2013, 05:16 PM | #1 |
1750
Rep 17,960
Drives: A Lot
Hi guys,
In the final stages of calibrating the OFT E40 OTS map. Test car is walker16's 2008 6AT with DPs, FMIC, DCIs and OpenFlash Tablet. 50k miles on the clock. Original turbos. This power level is supported on E30 but E40 is suggested for enhanced safety margin. I suspect we can squeeze out a little more next week when we finalize and release the tune to the public. Cheers, Shiv |
10-04-2013, 06:48 PM | #6 |
1750
Rep 17,960
Drives: A Lot
I did all the log viewing on the OFT new graphical data screen. Have some csv data saved on Walker16's OFT. Next time I get my hands on the car, I'll download them and post them up. Peak boost is just over 18psi tapering to around 16psi at 6000rpm. Timing advance is 13-16 at WOT. AFR target is in the mid 12s so still quite conservative. Cheers, Shiv |
10-04-2013, 09:09 PM | #8 | |
Rep 2,842
Since I will only be running pump 94 + meth, can I assume that the main timing table can be user-adjusted downwards about 4 degrees or so? |
10-04-2013, 09:31 PM | #9 |
Rep 414
Perfect I have been waiting for you guys to come out with an E30ish map. I think i'm going to try this before going with a full procede oft stack. How is the drivability compared to a procede stack?
"And just one question I might ask yah, and it might sound like A disaster, can you make this thing go faster?"
10-04-2013, 11:40 PM | #11 |
Rep 2,172
Hey Shiv... Looks really good... Are you able to log WGDC now so we can fix the boost issues / throttle closures and hit boost targets up top?
10-05-2013, 11:07 AM | #12 |
Rep 808
Don't hold your breath. I was told there would be something in a few weeks well over a month ago. And it looks like this E40 map is FBO, soo....
10-05-2013, 01:14 PM | #13 |
1750
Rep 17,960
Drives: A Lot
This is a replacement. But this e40 map will work on DCI-only cars as well. Also to be released is a stage 2 (pump gas) map. They are actually very similar with respect to boost control mapping. Differences are in fuel and ignition advance tables.
10-05-2013, 01:15 PM | #14 |
1750
Rep 17,960
Drives: A Lot
10-05-2013, 01:19 PM | #15 |
1750
Rep 17,960
Drives: A Lot
Graphical display update will be released (it's actually already released but you will need to update template file to access). After that we will be porting everything over to some other OFT applications. Then back to adding more user selectable channels. I hate given time frames. All I can say is that the new maps, datalogging and template file will be available next week.
10-05-2013, 05:55 PM | #16 |
Rep 388
+1
335 XI Coupe/ RB Turbos/ JB4 w/ Wedge Backend / Meth / Inline LPFP / E85 / UUC SSK / Spec2+ SMFW / HPF 7'' IC / Forged DV's / AR DP's / BMS DCI / Apex Arc-8 /Hankook Ventus V12 EVO / KWV1 / HPF Exhaust/ NGK/
10-05-2013, 05:56 PM | #17 | |
Rep 388
10-06-2013, 01:14 PM | #20 | |
Rep 2,799
thanks to MGallop |
10-06-2013, 02:28 PM | #21 |
Rep 300
Drives: '11 335i
This was done on my car and my fuel system is stock. I havnt noticed any issues since the dyno and I'm still the the e40 map.
I did order a proceed and will be getting the Vishnu pump and sensor soon. Finally broke the 400 whp mark now all I can think of is breaking 450!!! |
10-06-2013, 07:13 PM | #22 |
Rep 804
cant wait to try this out and have a little fun before i store her away for the winter.....dont have e85 here so just travelled cross the border to buffalo with a 5 gallon can and brought it home. Canada needs to get on this !!
how many gallons of e85 to half a tank of sunoco 94? |
