OFT Fuel issue...logs inside. Please help
10-18-2013, 09:35 AM | #1 |
Rep 408
OK. I am FBO with Vishnu OTS Fuel Flash and latest Procede with stage 3 maps. So I am having issues with fueling. I go super lean down low to super rich up high. Very much a straight line from about 15:1-10:1 from 2500-6500 every time WOT. Power feels weak and throttle response is slow. I think something is wrong with my final BIN file after I modify it. I have tried to do it 4 or 5 times with the same results. So either my stock file is modified already or I am doing something wrong. I have I8AOS. Can someone send me their stock BIN and fuel flash modified BIN? So then I can compare and see if/where there are differences or confirm or deny differences and causal. I did send several notes to Shiv with no response. So I am on here asking for some help with others who are using same set-up. Also should note I have tried different stages of maps including the 50/50 e85 maps.
My e-mail is badsz28@att.net for those who can send BINs to me. Or I can send mine to someone if they want to compare. Either way I appreciate the help. Thanks P.S. I also put stock BIN back into car and ran the standard stage 3 Proced maps and the car runs great till I run out of fuel...hence why I really want to get the fuel flash working. Added log screenshot. This is Procede Stage 3 maps with OFT OTS Fuel Flash. Notice how fuel trims are negative even though it is super lean? Then as you follow the RPMs up it goes richer and richer and fuel trims stay the same. EDIT: Adding datazap file. http://www.datazap.me/u/bads335/proc...ots-fuel-flash
2008-BMW-335i-E90-6MT-Sport-Montego Blue
10-18-2013, 09:57 AM | #2 | |
Rep 150
2008 135i RIP
2016 M3 |
10-18-2013, 12:26 PM | #4 |
3442
Rep 79,211
Try using http://www.datazap.me/
You will get a lot more responses to your logs if you use that medium. |
10-18-2013, 12:49 PM | #6 |
Rep 408
10-18-2013, 01:30 PM | #9 |
Rep 408
For the ProCede yes, but not in the OFT. I assume I just load the flash and go. I do not do any other functions on the OFT once the flash is loaded.
10-21-2013, 09:03 AM | #11 |
Rep 408
Before I post up a bunch of logs, I was hoping I could compare some BINs to make sure I am doing everything correctly. Can someone with I8AOS send me thier bins?
Thanks
10-21-2013, 02:00 PM | #13 |
Rep 408
Yes. I followed the instructions as stated. Changing the AFR table to 50.
Another thing I noticed when running the fuel flash is, with the Procede off, I see as much as 12psi. I would not think it would be more than stock (8.5psi). This is another thing that leads me to believe something is not right. |
10-21-2013, 09:47 PM | #14 | |
Rep 368
10-22-2013, 09:02 AM | #15 |
Rep 408
Well that's good to know. So what the hell is up with my fuel? I will try to get some logs up. I cannot do the datazap at work. So I will try to get some screen shots up for now.
10-22-2013, 09:47 AM | #16 |
Rep 408
Added a screen shot of what I am refering to in the first post. This is the same issue regardless of the procede map I run which leads me to believe there is an issue with the base tune.
10-22-2013, 10:43 AM | #17 |
Rep 408
I still would like to compare BINs. Can someone send me a stock and modified I8AOS BINs? I just want to check that what I am working with from a base is right before I work my way into other diagnostics.
Because if fuel trims are near zero, that means it is hitting the AFR target which is obviously wrong. |
10-22-2013, 12:18 PM | #18 | |
Rep 368
10-23-2013, 08:30 AM | #20 |
Rep 178
i ran my car on the dyno last night and i am having the same problem(I8AOS as well). im at 1 for OL fuel in the procede adjustments and im still getting negative fuel trims (-3-5). im going to send shiv all my info tonight and hope he can help me out.
Did you try adjusting the OL fuel in the procede settings as the "read me" file said to do for the fuel flash, so it wont be as negative at it currently is? |
10-23-2013, 09:02 AM | #21 |
Rep 408
Added datazap to first post. And below.
http://www.datazap.me/u/bads335/proc...ots-fuel-flash At least I think. I cannot view at work. |
