Track advice needed (e92 335is)
10-18-2013, 07:59 PM | #1 |
Rep 197
I'm not sure whether i should go with tires on my OEM 19" wheels or to get my coilovers first. I'm getting ground control w/hybrid camber caster plates, the school/street kit. I was considering getting pilot super sport in oem size 225F 255R. I just want to take advantage of the track day and be able to enjoy my car. Aside from the obvious brake fluid/pads the above mentioned parts are a big weakness, also without forgetting the oil cooler.I know also that OEM 19" are not ideal for track but i really don't want to buy dedicated wheels, mine look pretty cool. Opinions, suggestions, comments wanted.
10-19-2013, 09:27 AM | #3 |
Rep 4,110
Drives: BMW M3
The car is capable on the track without modification; prioritize getting high-temp brake fluid.
19" OEM are a little heavy, both weight-wise and economically; you could just about get a dedicated wheel/tire setup for the track considering the price of 19" PSS. A dedicated setup will pay for itself after a couple of events. You'll figure out pretty fast that no one cares if your wheels look cool on the track. See this thread, lots of the same info you're probably looking for: http://www.e90post.com/forums/showthread.php?t=878329
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT |
10-19-2013, 07:07 PM | #4 |
Rep 197
what do you suggest, i was thinking apex arc8 but they're not cheap plus a set of wheels. I dont know if i understood right but did you mean with i could get a dedicated wheel/tire for the price of "19 pss? Which tire/wheel combo would that be? Thanks for your help.
10-20-2013, 10:37 AM | #5 |
Rep 4,110
Drives: BMW M3
Yeah go check the classified section here, or your regional forum - plenty of people sell wheels and tires. It doesn't need to be special, but you can get get something for under $1,000.
01-08-2014, 02:51 PM | #7 |
Rep 158
Were are you located? Vendors got some great deals on wheel/tire packages. I was quoted 1950 mount/balance and installed for arc8s and nitto nt01s
