Single Turbo + ER CP / Tial BOV = Weird Noise?
10-20-2013, 04:51 PM | #1 |
Rep 334
Alright guys, I seem to have an issue here with my custom single turbo setup using the ER Charge pipe. I am getting a high pitch noise when it's part throttle and I let go off the throttle.
You can hear the noise clear as day at the 44 second mark. https://www.facebook.com/photo.php?v...type=2&theater I have tried a softer spring, changing out vacuum lines, and I directly hooked the vacuum line from the BOV to the intake manifold, still same issue. Please note in this video my boost gauge is not hooked up.
24 XM(Current)
22 X540i(Sold) 21 M5 Comp(Sold) 07 Single Turbo 335i(one of the first, sold) |
10-20-2013, 04:58 PM | #2 |
BimmerPost Supporting Vendor
1339
Rep 1,701
Drives: Slot Machines.. Keep Taking $
You need to log to see what your boost spikes to when you let off before the BV discharges. I'm not hearing anything wrong. I have Forge DVs and they make an URCH sound when they discharge. I get about a 2 to 3 PSI surge before they discharge.
10-20-2013, 07:57 PM | #4 |
Rep 374
How old is the bov? They can get dirt and stuff in them that make higher pitch discharges from the cylinder scratching on the dirt when it opens.
2008 335xi AT
Cobb AP stage 1, drop in filter, the rest stock 13.10@106.01 w/ 1.86 60' (5,800' altitude) |
10-20-2013, 08:07 PM | #5 |
Rep 334
It's brand new.
24 XM(Current)
10-20-2013, 08:56 PM | #6 |
Rep 1,392
Make sure it's the 11psi spring required. I had to disassemble my brand new tial and lube the inner guide. After that mine started working perfect for the last year. You may be having the same issue. From what i can tell it's not blowing off correctly.
Have a single turbo and/or tired of burning up O2 sensors? Ask me about the new ADV O2 sensor retro kits!
335i 2010 e92 M-sport Mods: VM Top mount 6466, Aquamist HSF4 w/custom direct port. VRSF IC + Exhaust 335i 2009 e90 665RWHP VFF900 ST RIP . |
10-20-2013, 11:20 PM | #7 |
Rep 1,525
bov
Didn't you put a different vaccum source on your intake?
10-20-2013, 11:47 PM | #8 | |
Rep 1,392
10-21-2013, 12:03 AM | #9 |
Rep 1,525
bov
So you had fixed the issue by lubing the tial then you did the mod tp the intake...I see! What did you lube it with?
10-21-2013, 12:18 AM | #10 | |
Rep 1,392
10-21-2013, 01:50 AM | #11 | |
Rep 1,525
bov
