10-28-2013, 09:03 PM | #1 |
Rep 803
How to recover files from an SD card?
So I have a couple micro SD cards that I kept in my wallet when I was younger, and it looks like they broke.
Whenever I put it on the comp it says "no SD card found." One has a hairline crack going down the middle, and the other may have broken too. Was wondering if I could recover the files/pics in any way.
black/black/black e92 loaded
Instagram: _eamon_ |
10-29-2013, 10:36 AM | #5 |
Rep 534
Nothing is impossible. Get a software called stellar recovery. It will scan the sectors of the drive and my be able to retrieve all the data. Important to not over write the sectors on the sd card by taking additional photos.
This is all continent on getting the pc to see the drive. Buy a cheap card reader crack the plastic and make sure all the connectors are touching. Good luck
10-29-2013, 12:17 PM | #6 |
Rep 2,095
Drives: 2019 Toyota Tacoma TRD OR 4x4
Try using a software called Recuva. Its worked great for me in the past. Also, if you're using MS Windows and don't see the drive at all, try creating a bootale Ubuntu usb and see if you can see the files on the sd card that way.
E90 325i|Sparkling Graphite Metallic|Steptronic|Black Leatherette/Dark Burl Interior|OEM Alarm|35%Front/5%Rear Tint|RD LED License Plate Lights|Rear Fogs Activated|Debadged|Smoked Sidemarkers|Blacklines|Depo P90v2|Matte Black Grille|BMS PBX|AFE Drop In|Charcoal Filter Delete|Air Scoops| RM Silicone Intake Hose| Magnaflow 14815| 19" Avant Garde M310|Continental DWS|M3 Lip Spoiler
10-29-2013, 01:27 PM | #7 |
Rep 1,268
Give it up they are loss cause, if you have crack cross them and they are not even recognized that means they are broken, you probably crack the actual memory chips inside the card itself
Here is what the insides look like, if you bent it enough to crack the outside most like the chips in side are crack as well http://www.hardwaresecrets.com/imageview.php?image=5287 |
10-29-2013, 03:53 PM | #8 | |
Rep 1,684
The best company: Ontrack Data Recovery. Send them your data---hand deliver it if it's really valuable. If they can't do it, no one can. These nuts recovered data from the space shuttle flight data recorders when it was nothing but a charred ruin. |
10-29-2013, 06:10 PM | #9 |
Rep 803
10-29-2013, 09:24 PM | #10 |
Rep 1
Hi, for the SD card can't be recognized problem, you can refer this article: How to Fix “USB Device Not Recognized” Error If you need to recover lost data from this card, you can use Remo Recover, you can find it in the page Recover Photo from Nikon Digital Cameras
10-29-2013, 09:36 PM | #11 | |
is probably out riding.
6062
Rep 2,292
"There is no greater tyranny than that which is perpetrated under the shield of the law and in the name of justice. -Charles de Secondat"
10-30-2013, 09:54 AM | #12 |
Rep 1,268
Op, based on your pictures it is safe to say the chips inside the card are cracked and will not function at this point. There is nothing you can do about that.
10-30-2013, 09:57 AM | #13 | |
Rep 1,268
10-30-2013, 11:57 PM | #14 | |
Rep 1,684
10-31-2013, 12:16 AM | #16 |
Rep 1,268
You did not tell him how that would cost. I did a HDD one time and had the manufacturer do it since they are most knowledgeable on drive recovery my driver was not damaged and it cost $1200, it was worth it since it was years of data and the backup was corrupted as well.
Not that the SD card could not be recovered but once the chips are broken it becomes very hard depending how they are broken. The other issue with and SD card is the fact NAND Flash does not hold its data for long period of time. Most Flash is not recoverable if more than a yr old and has not been powered up. |
10-31-2013, 12:20 AM | #17 | |
Rep 208
10-31-2013, 02:38 PM | #19 |
Rep 345
Drives: '08 335i, '03 Kawa Z1000
After seeing the pics BMWrules7's advice is the best, but it will cost thousands.
