DEFIV Fabrication Direct Port Methanol Setup - Tuning Begins
10-29-2013, 09:30 AM | #1 |
Black on Black on Black.
38
Rep 532
After the direct port methanol setup was completed, strapped on and shaken down we sourced a BT Cable from LostMarine so that Rick of DEFIV Fabrications could begin tuning in earnest.
The last log from that day is here: http://datazap.me/u/uniter/defiv-fab...ce-added?1-5-6 Rick was able to add in additional timing as well as pull out timing advance / IAT compensation values (DEFIV is experimenting with their own IAT sensor but softening the compensations tables does the same ATM.) The DEFIV Plate can accommodate a fuel rail, methanol and nitrous nozzles all at the same time. Here's a shot of the nozzles spraying in a test run: The Procede is doing a good job of managing the PWM Meth injection system and introducing more timing advance on top of the flashed values. I'm sure that any HFS-4 system could do the same. All in all I'm enjoying the new-found power, I'm confident that I'm getting well metered equivalent flow into each cylinder. As a final note the support I received from the Procede team and Robert was top-notch. These guys know, love and support their product. Thanks!
LEMANS BLUE M-TECH E92->PROCEDE REV3::BIEHNTUNE FLASH::ETS 7" FMIC::RACELAND DPS::OS GIKEN 1.5 WAY::DEFIV DIFF LOCKDOWN::DEFIV OCC::DEFIV INTAKE::RB PCV |
10-29-2013, 09:59 AM | #2 |
Rep 6,478
Whoa Rick is tuning your car? That’s awesome, and I had no idea he was cooking this up for the N54. Is it a one-off?
Also to be clear- you are still using the PROcede to control meth via PWM/Injector DC, but the actual spraying is done via port injection through the manifold. So the only “difference” is physical location/amount of spray, correct?
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
10-29-2013, 10:00 AM | #3 |
Not Baned
87
Rep 1,354
I've always been very worried about direct port meth injection. If one Nozzle(s) clogs that Cyl in Toast! :-/
But working perfectly im sure you'd get sick gains! I would try and PLENUM Injection style and see how that compares. I would also add 1 small meth nozzel before the IAT sensor so that it sees the drop in Temps and allows the DME/Procede to Adjust timing accordingly... Keep us posted man! Great Job! |
10-29-2013, 10:06 AM | #4 |
38
Rep 532
135Pats: He does have it in solidworks so.... probably not a one-off Have I seen you at the shop or do you have a different car there? Right so the procede handles all the injection and tuning. One should be able to keep everything, pump, FAV and flow sensor and just attach the DEFIV bits.
JMARS: We've have that idea + we have an IAT sensor in port + biasing the IAT signal during WOT and METH conditions. So we'll figure out what works best. There's lots of filtration in this setup; the procede is fast to respond to changes in flow, quality meth is being used. The likely-hood of a nozzle clog related engine explosion is low.
10-29-2013, 10:20 AM | #5 |
Rep 20
The reason I leaned towards plate as opposed to plenum injection is because in it's final incarnation it will be capable of supporting 6 additional fuel injectors, water/meth nozzles or direct port nitrous oxide. It could use any pairing of the aforementioned options, it was designed with all of that in mind...this is just a prototype atm...there will be plenty more holes available in the final version
10-29-2013, 10:39 AM | #7 | |
Rep 6,478
10-29-2013, 10:44 AM | #8 | |
38
Rep 532
10-29-2013, 12:10 PM | #10 |
38
Rep 532
The fact that the procede can drive the meth fast action valve directly and control ignition advance accordingly is really amazing. Everything wired right up and worked.
10-29-2013, 11:05 PM | #12 |
Rep 1,079
Your power steering reservoir looks different than mine...Is that original?
2004 E46 M3 | Imola Red on Cinnamon | Slicktop | Manual Seats | 6spd MT |
10-30-2013, 08:37 AM | #13 |
Rep 6,478
I think? It’s from an F10 5 series. Or maybe that was an F10 coolant expansion tank I saw swapped into an N54 on another thread. Def not a stock N54 PS tank.
10-30-2013, 08:38 AM | #14 | |
Rep 1,079
10-30-2013, 10:00 AM | #15 |
38
Rep 532
It's the tank for the 'adaptive steering' systems.
10-30-2013, 10:30 PM | #16 |
Rep 725
ptf MHD E85 /Hexon rr550 turbo's/PRE custom intakes/CP / bms dp's/hfs4 / er fmic/PSS/spec stage 2+/kwv2/steveAZ stage 3 lpfp /m3 control arms/powerflex black/MF LSD /fuel it port injection
10-31-2013, 08:18 AM | #17 |
DIYER
614
Rep 5,521
Great !!! A reason for me to add more 4-AN fittings lol! Can't wait to see this in action.
JB4 G5, Stage 3 LPFP, Stage 2 MOTIV PI, VM 6466 ST, Custom OCC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2, DEFIV kit, KW clubsport, Delrin solid SF bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, M3 fenders, M3 OEM sideskirts, Mtech rear bumper, CSL trunk, MORR VS8.2 rims 245/295
10-31-2013, 11:10 AM | #18 |
Rep 3,961
Whats hapens when 1 nozel clogs and you don't know it?
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
10-31-2013, 12:37 PM | #20 |
Rep 1,257
If this is designed to run injectors as well, why even mess with the meth side of it? Why not just add more fuel(corn or dinosaur farts) and call it a day? With a direct port meth system, are you even getting any of the cooling benefits, or are you just getting the added octane boost? If only octane, the meth side of this seems even more of a waste...and a potentially dangerous one at that.
Overall, nice to see a potential source of extra injectors finally coming around and excited to see where those get us. The meth portion though....ehhhh... |
10-31-2013, 01:05 PM | #21 |
Rep 6,478
Unless you have enough octane and in-cylinder cooling to keep things happy without it, sudden loss of methanol spray to an individual cylinder would rapidly cause expensive metal parts to melt. Not good.
10-31-2013, 01:45 PM | #22 | |
Rep 1,690
Very interesting setup but I have to agree with pwr hungry. Why not just spray more fuel? Ask Turb0Mike about how he feels about meth...
