Recommended map COBB accessport
11-10-2013, 05:34 PM | #1 |
das Eichhörnchen
46
Rep 279
What cobb map to run with:
ETS 5" FMIC, downpipes, ER chargepipe, NGK plugs, stock air filter. I read some posts saying stage 1 aggressive performs better than some stage 2 maps, I have 93oct available. |
11-10-2013, 07:13 PM | #7 |
das Eichhörnchen
46
Rep 279
I guess Stage 2 Aggressive it is
My car seems to run excellent now on Stage 1 Sport, since I did this in past two weeks: 2 new front o2 sensors (on dps), 6 new coils, new NGK plugs, oil change, and the mods above. I changed all coils/plugs because I got a misfire code/coil code, so I was also going to send my logs to COBB. |
11-10-2013, 07:30 PM | #8 |
Rep 650
Log and see if you're happy with the amount of timing pulls. Depending on the quality of your gas, even though it's rated at 93, you may end up happier with Sport than with Aggressive. But you will want the extra boost of Stage2+ regardless.
11-10-2013, 08:26 PM | #9 |
Rep 6,478
Log Stg2+ Sport just to make sure the hardware is ready to go on a conservative timing curve, then log and run E30 if possible.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
11-10-2013, 09:50 PM | #10 |
BimmerPost Supporting Vendor
15
Rep 678
you should be on stage2+ aggressive with your mods. Which variation depends on the fuel quality.
you have 93 where you are. I would load stage2+ sport and log, if all looks good then stage 2+ aggressive it is |
11-12-2013, 09:45 PM | #11 |
das Eichhörnchen
46
Rep 279
Hey sorry for the late update guys.
So the same night, I flashed to Stage 2 Sport, and went for a midnight run. The car is very strong smooth, runs excellent with all the new parts and mods. I try to only fill up 93oct at Chevron, but I'm still hesitant on trying the Stage 2 Aggressive. |
11-12-2013, 09:52 PM | #12 | |
Rep 6,478
Log and post it here.
11-12-2013, 11:50 PM | #13 | |
15
Rep 678
Btw, by stage 2 you mean stage2+, right? |
11-13-2013, 10:41 AM | #14 |
Rep 147
i would suggest if you have a manual doing stage 2+ aggressive and etting the free pro tuning available and improve it a bit. if you have an auto or manual with upgraded clutch the e30 map is alot more fun.
11-22-2013, 01:43 PM | #15 | |
das Eichhörnchen
46
Rep 279
I guess I'll leave it on sport even though I have 93oct here. |
11-22-2013, 02:04 PM | #16 |
das Eichhörnchen
46
Rep 279
I might try aggressive. Don't get to drive too often anyway, places that are fun are at least 2 hours away. No time
11-22-2013, 02:06 PM | #17 |
15
Rep 678
11-22-2013, 05:31 PM | #19 |
das Eichhörnchen
46
Rep 279
I used K&N in the past, not a huge fan. And I'm not going to change the airbox or get a DCI.
Anyone use the pipercross or AFe filter? Those are the other two options I see on ecs tuning. p.s. the car seems to be happy with the stock air filter. I do replace it pretty often usually with every oil change (3000 miles). |
11-22-2013, 06:05 PM | #20 | |
das Eichhörnchen
46
Rep 279
There is one Chevron gas station about 20min away from me with e85. |
11-22-2013, 06:15 PM | #21 |
Rep 6,478
READ. And then download the map to your AP, give it a few pulls to adapt, and log.
It's so much better than the pump gas maps. Runs too rich IMO but all in all it's a nice map for E30. http://www.cobbtuning.com/Accessport...ap-Datalogging
11-23-2013, 12:50 AM | #22 |
Rep 3,189
I am FBO with AFE stage 2 intake just on pump fuel.
While logging I could notice a loss of power down low with the stock intake. I went back to stock intake to check IAT temps with AFE stage 2 and the stock intake. (IAT the same with both intakes on highway WOT and cruise) IMO car likes the aftermarket filter. Anyway.. as long as your log your map changes |
