2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums CANADA Snow Tires for F10 535i xDrive
      11-11-2013, 09:21 AM   #1
Hut
Drives: 2013 328i & 535i xDrive
Shopping for snow tires for my 2013 535i xDrive (non M-Sport)
Stock size is: 245/45R18
Any recommendations?
Thanks!
      11-12-2013, 05:38 AM   #2
bobblehead
bobblehead's Avatar
Drives: warp speed
Michelin PA4
Bridgestone LM60 (being discontinued but still selling) or LM32 (new)
Dunlop WS 4D
In toronto, you can check out Simply Tires, Joy City. Reasonably priced shops.
If you need wheels, check out BBS CH-R, approx. $3300 a set, if you have the budget for them. Otherwise, replicas would be okay but the quality is hit & miss.
      11-12-2013, 08:58 AM   #3
Hut
Does anyone know the 18" wheel size for 535i (non-sport)? Is this correct?
Tire: 245/45 R18
Rim: 8 x 18
Offset: ET30 or ET35?
Bolt pattern: 5 x 120
Center bore: 72.6
Thread size: M14 x 1.25 ?
      11-12-2013, 02:29 PM   #4
bobblehead
bobblehead's Avatar
Drives: warp speed
^ everything is correct
et is 30
      11-12-2013, 08:09 PM   #5
Hut
et is 30
Offset 35 would fit as well, right?
      11-12-2013, 08:18 PM   #6
bobblehead
bobblehead's Avatar
Drives: warp speed
no problem.
I guess this is aftermarket wheels as I don't recognize this being an oem wheel with this offset.
      11-12-2013, 08:48 PM   #7
Hut
no problem.
Yes, you are correct. I'm looking at these ones:
http://www.rtxwheels.com/en/content/berlin-bmw
http://drift-wheel.en.hisupplier.com...WHEEL-RIM.html
      11-13-2013, 06:23 AM   #8
bobblehead
bobblehead's Avatar
Drives: warp speed
Just make sure you run on the highway after install, the objective is to make sure there is no vibration even though it says they are hub centric, only the stock oem wheels are TRULY of that. If you have issue, then go back to the shop and ask for Road Force balancing as to reduce (not eliminate) the vibration issue.
5post
