-40F Temperature 335i
11-11-2013, 11:41 PM | #1 |
Rep 62
Hey. My temperature reads -40F. I already looked through the forum and found where the sensor should be located. I bought a new sensor and plugged it in, it didn't work. I bought a new sensor again and a new plug with wires and again it still reads -40F. I plugged the new wires directly onto the old wires higher up but nothing worked . i found no damage along any part of the wires. This should have been an easy fix but i'm stuck. Maybe I need to reset the temperature with and obd scanner ?? I have no idea .
Please Thank you |
11-12-2013, 12:09 AM | #2 |
Rep 2,731
Are you sure you replaced the temp sensor which is in the front bumper?
You might have replaced the air quality sensor which is in front of the passenger by the microfilter on the windshield cowl. Temp sensor looks like this... |
11-12-2013, 03:52 AM | #4 |
Rep 1,392
It would be odd but not impossible see if the two wires are touching. I believe it works like most temp sensors resistance increase with temp increase. So showing that cold means your output and input voltage is 5v. Check wiring with a multimeter.
Have a single turbo and/or tired of burning up O2 sensors? Ask me about the new ADV O2 sensor retro kits!
335i 2010 e92 M-sport Mods: VM Top mount 6466, Aquamist HSF4 w/custom direct port. VRSF IC + Exhaust 335i 2009 e90 665RWHP VFF900 ST RIP . |
11-12-2013, 12:41 PM | #7 |
Kraut Driver
59
Rep 624
Drives: 2014 650i GC/2011 335is DCT
Damn that's a cold ass honkey
11-12-2013, 12:45 PM | #8 |
Rep 3,552
12.0 @ 117 |
11-13-2013, 01:41 PM | #16 |
Rep 1,268
Did the car through a code, if so in the linked thread above it says you need to clear the code before it will show the correct temp. This sensor is uses for various things besides telling you the outside temp, your air condition will not work properly with this being wrong.
11-13-2013, 02:50 PM | #17 | |
Rep 62
11-13-2013, 03:20 PM | #20 |
Rep 965
Drives: e92 m3
I had the same problem,did u take of ur bumper or did any work behind the bumper?
the temp sensor is located on the driver side but the wire runs thru passenger under the headliggt. my problem was pinched wire from swapping bumper. follow that wire n see if it's ripped or anything.code will clear ones it works again.
e92 m3 dct
gintani stage 2+ full ethanol custom pulley and meth kw clubsport,ap racing radical,volk te37sl,akrapovic rear,recaro profi xl,voltphreaks battery |
11-13-2013, 06:44 PM | #22 | |
Rep 62
