11-16-2013, 11:21 PM | #1 |
Rep 49
Prodrive GC-012L on M135i
Rims are Prodrive GC-012L with Michelin PSS: 225/35R19ET44 (19x8.5) front and 255/30R19ET51 (19x9) rear, sills with M Performance stickers, not very standout but feel just right, ride height seems a bit too high after wheel change for unknown reason (on paper should be almost identical to OE)
More can be found on flickr: http://www.flickr.com/photos/2141956...7637750058326/
2001: Pegueot 206GTi
2009: VW Golf GTI MK6 2013: BMW ///M135i |
11-17-2013, 01:06 AM | #2 |
Rep 49
FYI: if you are interested in the unsprung mass reduction, it is about 6lb (2.7kg) per wheel - for instance rear wheel + tyre from 52lb down to 46lb.
11-17-2013, 02:22 AM | #4 | |
Rep 49
11-17-2013, 05:23 AM | #6 |
Rep 2,183
Drives: .
Garage List 2018 Audi RSQ3 (8U) [0.00]
2022 BMW X3 xDrive3 ... [10.00] 2015 BMW M235i (F22) [10.00] 2017 Mini Cooper S ... [0.00] |
11-18-2013, 08:14 AM | #8 |
Rep 49
Indeed... btw anyone has experience with M Performance Chassis? (Claimed to stiffen a bit plus lower another 10mm compare to Non-adaptive M Sport Suspension)
11-23-2013, 05:47 PM | #9 |
Rep 2,064
Looking good!
2004 e87 118d (ret.), 2007 e92 330d (ret.), 2007 e87 130i M-sport (ret.), 2009 e92 M3 (ret.), 2010 f10 535d M-sport (ret.), 2015 f10 M5 CP (ret.), 2017 f82 M4 CP (ret.)
2022 g26 i4 M50 & 2009 e70 X5 35d |
11-24-2013, 04:33 AM | #10 | |
Rep 490
There are also options of lowering with Eibach or H&R springs with using exsisting dampers and also option with coilovers like KW or Bilstein
2022 BMW M340d saloon
11-24-2013, 06:51 PM | #11 | ||
Rep 49
11-25-2013, 05:12 AM | #12 | |
Rep 490
http://www.prodrive-japan.com/produc...012l/size.html I think you may have the 8.0 ET45 front wheel as 8.5" ET47 doesn't seem to be available? Maybe that's why it doesn't look as far out as they only stick out more by 6mm front if that's the case
