E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > 2012 335is with Battery Problems
Reply
      11-24-2013, 01:53 AM   #1
rl335IS
Drives: 2012 335is vert
I purchased a pre-owned 335is convertible a few months ago that only had 3000 miles on it. It now has around 5500miles. Over the last month, it's been giving me high battery discharge and low battery errors. I have a battery charger and have charged it overnight, and a day or two later the issue comes up again.
Last week I took it to the dealership and all they did was charge it overnight. I drove it, and left the radio on (engine off) for only 7 minutes and the low battery error came up again! My commute is fairly short so I can understand if it's not fully charging, but I had just picked it up after a full charge.
I've seen alot of threads on battery issues, but I don't remember seeing a fix.
Any suggestions? Thanks!
[SOLVED...I hope, see post #17]
      11-24-2013, 01:55 AM   #2
tmdals0213
tmdals0213's Avatar
Drives: 2016 340i M-Sport
they wont replace it?
Diligentia Vis Celeritas
      11-24-2013, 02:16 AM   #3
rl335IS
I called the service rep immediately after and he didn't even return my call. I haven't had a chance to schedule another service appointment.
      11-24-2013, 05:13 AM   #4
SilverII
Drives: '11 335IS
2011 BMW 335IS  [9.66]
i got a low battery warning and the dealer replaced the battery
      11-24-2013, 01:38 PM   #5
rl335IS
When I brought it in, I told them that I've charged it with a charger several times in the past and the problem still existed, and that I hoped they would do more then just charge it. The SA said they have to follow the process, otherwise BMW wouldn't pay for a new battery. Apparently the process included wasting customer time as well.
      11-24-2013, 01:58 PM   #6
AgentAvalos
VIP
AgentAvalos's Avatar
Drives: AW E92 335is
2011 BMW 335is  [0.00]
isn't it under warranty?
      11-24-2013, 02:07 PM   #7
rl335IS
Yes, warranty and maintenance
      11-24-2013, 03:02 PM   #8
DML
DML's Avatar
968
Drives: 2020 Heritage
Just take it in for service that's the beauty of a late model Bimmer
      11-24-2013, 03:14 PM   #9
BigFoig
Drives: e92 335is
They replaced mine the first day
      11-24-2013, 03:26 PM   #10
marc@x-ph.com
BimmerPost Supporting Vendor
15
Drives: 2010 e92 335i
Just take it in. If he doesn't answer your calls, ask the operator to walk over to him and make him call you
      11-24-2013, 11:35 PM   #11
fazman
Drives: 335 e90
Contact BMW NA customer service, ask them for the name and postal address for who can accept legal documents. Tell them u are having an issue with your car battery after several attempts and you are looking to
initiate a manufacturer buy back. I'm sure they will toss in a battery for u in the next visit. The dealer cost of the battery is not the same as te customer cost. They sell it to u for $500... but their cost is like $50.
      11-25-2013, 09:36 AM   #12
mump
mump's Avatar
Drives: '11 E93 335is/'01 986S/'13 F30
I was at the dealer about a week ago with my '11 335is e93. The guy asked me if I wanted to do the "battery recall" for my car. I thought he was talking about the battery cable, which I answered that they did it a couple months back.
His answer was "No not the battery cable but the actual battery itself." He stated it was the first time he had seen that kind of recall but it popped up when he checked the service with my key fob. Might want to check into that...
      11-25-2013, 09:50 AM   #13
AGO 530
AGO 530's Avatar
Drives: SG '24 M3CX
2017 BMW M3  [0.00]
There was a battery recall a few years back, my service advisor told me that the car requires a re-programming to incorporate the increased battery size (70amp to 90amp), may throw codes without the update. If you have the 70amp battery, it was never replaced.
SOLD Mineral White '17 M3 Comp / Dinan S2 / FBO
SOLD AW '15 435i F36 Msport / EUROCHARGED TUNED, STAGE 2 / FBO
SOLD AW '11 335i E90 MSport FBO
      11-25-2013, 12:20 PM   #14
Tom K.
Tom K.'s Avatar
Drives: '07 328iT, '13 Boxster
And if your car has had the cable recall, have your dealer check the IBS unit (which is in the other cable). An intermittent IBS fault in mine resulted in low battery warnings, stalling, and ultimately a battery failure.
Tom
      11-26-2013, 12:13 AM   #15
rl335IS
So when I took the car in last time, I asked him if the car had any recalls and the SA said no. Not sure if he was being lazy, or whether the '12 doesn't qualify for the recall. Do you guys happen to have the bulletin numbers on these 2 recalls?
Thanks!
      11-26-2013, 09:51 AM   #16
Tom K.
Tom K.'s Avatar
Thanks!
The number on the ticket for my '07 E91 battery cable recall was SIB# 61 02 13.
However according to this article, your SA may be right:
http://www.usatoday.com/story/money/...ables/1924627/
Tom
      12-07-2013, 04:06 PM   #17
rl335IS
Just to update this thread, I took the car in yesterday. When the SA put the key into their reader, a recall popped up immediately. Not sure why that didn't happen before.
In any case, here's what it says on the service paperwork:
B61 16 13 E93 Battery
Recall Work Package
50099 W
1 61-21-2-353-812 EP Battery 92AH: 612010
5869 Performed SIB 61 16 13 For battery reall defect code: 00 61 89 03 00
Labor Operation: 00 61 870
Labor Allowance: 7 FRUs, Check and replace the "Banner" battery (Coding conversion with ISTA/P is not required)
No charge. It's only been a day so I can't say definitively this fixed my problem, but I'm very hopeful. Will update this thread if the error pops up again.
Reply
e90post
