Log Analysis
12-10-2013, 03:07 PM | #1 |
Rep 86
Log Analysis
I logged some pulls today with my Cobb AP to make sure everything is looking okay.
After reading a DIY here, I logged the car from 2nd through 3rd gear. I'm now realizing that most people want to just see a full 3rd gear pull. If this is an issue, just let me know and I'll grab some more runs. The car is an 08 and is completely stock with 45,000 miles. I'm running stage 1 aggressive as finding 93 octane where I live isn't an issue. Please see my datazap link below for access to my two logs.... http://datazap.me/u/coby Thanks! |
12-10-2013, 03:29 PM | #3 |
Rep 86
Thanks, that's great news! I've got to say the car certainly didn't feel like it had any issues but I'm pretty new at this so I wanted to make sure.
My main problem was getting traction. I was attempting some 0-60 runs but the best I could get was around 5 flat by feathering the gas. Time to ditch these stock RFTs I guess... |
12-11-2013, 04:31 AM | #4 |
Rep 7,377
yeah run 3rd gear only instead and shift to 4th.
12-11-2013, 10:59 AM | #6 |
Rep 86
Can anyone comment as to why the actual vs requested load and the requested boost abs. vs boost mean abs. are so off at the beginning of the pull in the lower RPM range (1500 - 3000)? It's fine if it is normal, just trying to understand it a bit better...
12-11-2013, 12:05 PM | #7 |
Rep 7,377
is normal. everything looks great.
12-24-2013, 11:46 AM | #9 |
Rep 86
started to misfire a week after the aggressive tune so I replaced my plugs and dropped a k&n into the intake. seems to have fixed the issue.
ran a 3rd gear log today .... http://datazap.me/u/coby/3rd-gear-12242013 |
12-24-2013, 11:49 AM | #10 |
Rep 6,478
There's a bit of noise around 4.5K revs, tough to say why without knowing more, but nothing to be super concerned about. If you have a means of upping the octane a bit, that's never a bad thing on this platform. The corrections are minor and work themselves out quickly, all in all log looks OK to me.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
02-06-2014, 03:52 PM | #11 |
Rep 86
not too good at reading these logs yet but I'm thinking my latest one doesn't look too good....
anyone care to comment? would appreciate the help... http://datazap.me/u/coby/3rd-gear-262014 |
03-28-2014, 10:39 AM | #12 |
Rep 86
just had my hpfp and lpfp sensor replaced due to a rough idle. grabbed a log yesterday on the way back from a business trip. I know I'm in need of a walnut blast as I'm approaching 50k but the car seems to be running fine minus. I am throwing a couple of misfire shadow codes though....
if anyone has time, can you check it out and let me know how it looks? http://datazap.me/u/coby/32814-3rd-a...gear-93-octane |
