NGK plugs and cold start
12-15-2013, 01:59 PM | #1 |
Rep 2,189
Had a misfire in cylinder 5 only when running map5 with E85, replaced all the plugs with NGK's, gapped them perfectly to .022 with a feeler gauge and on the first start of the day it runs slightly rough until RPM's drop to 600 then it runs perfectly the rest of the day.
No more misfires and it runs strong again otherwise. I assume this is normal? |
12-15-2013, 02:08 PM | #2 | |
Rep 2,799
thanks to MGallop |
12-15-2013, 03:12 PM | #4 | |
Rep 2,189
I noticed a date on them, 07/06/2013 to that effect. When I did the plug changed I swapped coil 1 and 5 to aid in troubleshooting, no misfire codes yet. |
12-15-2013, 03:14 PM | #5 |
Rep 2,189
12-15-2013, 03:16 PM | #6 |
Rep 1,677
I had a similar issue but I forgot which cylinder. And it fixed the issue. I think the recommended 0.022" gap is just too aggressive. It's possible, you're injectors are leaking if the issue continues.
I would try to go with gapping to 0.024" first and if it doesn't fix it, go back to stock, just for cylinder 5 to see if misfires go away. Then on to coils, injectors then valve cleaning as the last resort. |
01-01-2014, 01:04 PM | #8 |
Rep 2,189
Gapped them to .24, no difference.
Not sure where to go next. I'm going to rule out intake valve cleaning, car only has 28K and the issue appeared overnight. If it were coils it wouldn't just be a cold start issue right? That would leave a leaky injector overnight as the issue? |
01-02-2014, 04:48 PM | #9 |
Rep 2,189
I called BMW and check about the injector recall to see if they were original injectors and it had the HPFP and injectors replaced back in 2011.
The SA mentioned the injectors might still be under some kind of BMW warranty for the recall work and I did mention I have a 3rd party warranty also. So I might just give the car to BMW, see if it's still covered and if not try to fall back on the 3rd party warranty. Worst case I'll take the car back and just figure out which injector is causing the issue and replace/recode myself. I dunno, slightly disappointed I'm in this situation already after 5K miles of ownership but I did know what I was signing up for I guess. |
01-25-2014, 08:35 PM | #10 |
Rep 2,189
Just an update:
Switch back to factory plugs and cold start idle issue is gone. I reset adaptions and that helped a bunch but with the NGK's it still would mis a bit for the first 30 seconds. |
01-26-2014, 03:47 AM | #11 | |
Rep 32
Having a very similar issue after switching to the colder plugs. Difference is my misfire is occurring at WOT. Thank |
01-26-2014, 05:31 AM | #12 |
Rep 35
Recently replace my plugs with the ngk 5992. Gapped to .022 - .023 Warm idle feels slightly smoother but nothing significantly different on cold startup. Engine ticking at idle does sound louder then before.
Jb4 g4 (map 5) Bms dci HKS ssq Magna flow cat back |
01-26-2014, 10:53 AM | #13 |
Rep 801
E85 In the winter sucks. Probably that's what's making it misfire
14 M5 / comp / CCBs / alpine white
PG intakes Evolve tune Switzer exhaust Fabworx pipes |
01-26-2014, 10:54 AM | #14 |
Rep 3,552
Then its probably not your plugs if they are new and gapped correctly. check your codes and swap coils.
12.0 @ 117 |
01-26-2014, 02:33 PM | #15 | |
Rep 2,189
I've had no WOT issues though, just cold start idle issues. |
01-26-2014, 04:28 PM | #16 |
Rep 647
Have the same problem. Was getting misfires on cylinder 1 and 6 at WOT. Installed ngk plugs gapped to .22 and still would misfire at WOT. Had all my injectors replaced and came to find out both injectors 1 and 6 were installed without the crush ring. Now car runs strong at WOT but my first cold start of the day is rough and the car is misfiring enough to throw shadow codes. Won't trigger a cel, but when I scan for codes on my cobb it shows misfire on cylinder 3-4-6. Running 50-60% e85. I'll try putting my stock plugs back in and see if cold starts get better.
01-27-2014, 05:02 AM | #17 |
Rep 1,910
mine are gapped to .022 and I notice cold starts on e60 in sub 30 degree weather when I haven't started/driven the car for 3-4 days, can be quite rough.
Current: 2017 F30 340i xdrive
Previous: 2008 e92 335i coupe: RB turbos, mach 116 race fuel, methanol, alot of boost. Previous: 2003 Honda Accord V6 coupe: AEM V2, zex 75 wet shot (sold) |
