Took the 328 to the strip
12-20-2013, 09:37 AM | #1 |
Rep 9,004
15.18@90.1MPH was my best time and a 60ft of 2.299
I could have probably lowered the 60ft by launching at a higher RPM (was launching at about 2500) but I wanted to preserve the driveline and not break anything. I don't know how a automatic 330i was kicking off 97mph trapspeeds and I can't even crack 91mph. Gear ratios? Final drive? Car is verified healthy according to the dyno. |
12-20-2013, 11:31 AM | #2 |
just another bmw douche bag
195
Rep 3,640
your 60 foot time isn't doing you any favors. nearly 2.3 on the 60 ft will really add to your quarter mile time. if you cut that to 2.0, you'd drop nearly half a second on the back end. But then again, 90.1mph says otherwise.
did you bog on the launch at all? spin? if you are on regular street tires, you shouldn't have too much driveline stress, so launching higher would probably help. |
12-20-2013, 01:34 PM | #3 |
Rep 9,004
C/D test notes indicate they Dropped the clutch at over 5000RPM, I was launching around 2500 - even if I could get the 60ft down, the MPH just says it's not fast enough for mid 14s. And for the launch, it didn't bog, and spun just a little.
12-20-2013, 09:41 PM | #4 | |
Rep 525
maybe need a small tune-up, how are the plugs/coils/airfilter/etc...? Edit: didn't read your last comment, if on the dyno it checks than it's not the car, are you shifting just before hitting 7000rpm and fast enough? Last edited by bimmerquick43321; 12-20-2013 at 09:48 PM.. |
12-21-2013, 10:22 AM | #6 |
Rep 9,004
Ok, this is REALLY odd.
Run 1, I believe I missed second gear for a moment 60' ---- 2.290 300 ---- 7.084 1/8 ---- 10.781 MPH ---- 66.41 1000 ---- 13.831 1/4 ---- 16.303 MPH ---- 90.61 Run 2, bad launch 60' ---- 2.36 300 ---- 6.598 1/8 ---- 10.045 MPH ---- 71.22 1000 ---- 12.941 1/4 ---- 15.375 MPH ---- 90.68 Run 4, I was idling for a solid 10 minutes before hand 60' ---- 2.299 300 ---- 6.464 1/8 ---- 9.881 MPH ---- 71.6 1000 ---- 12.76 1/4 ---- 15.189 MPH ---- 90.12 |
12-21-2013, 03:52 PM | #7 | |
Rep 525
how were the other cars performing around? btw as already mentioned the 60ft could really be improved as you're manual, you had the same 60ft as my automatic, that's where the manual should shine and should cut .1-.2 compared to an auto on the 60ft, which will be around .2-.3 in the 1/4 mile time diff right there + it will help the mph as well... |
12-21-2013, 07:52 PM | #8 |
Rep 9,004
I'll try again, but the track doesn't open again until after the new year. I just don't see how I'm not trapping high enough, as I understand a 60ft time doesn't effect trap speed.
01-09-2014, 05:55 PM | #9 |
Freight Dawg
104
Rep 2,103
Where are you shifting? Don't wait until 7000 rpm. The N52 wheezes a bit up there. Shift at 6800rpm and launch at 3500 rpm. My performance box measured my 1/4 mi at 14.7. Don't remember the trap speed though. The performance box also start timing 1 foot after initial movement (no reaction time).
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors |
01-12-2014, 03:53 PM | #12 | |
Rep 9,004
Throttle response is also slightly improved (though I never really had an issue with it before) and part throttle response is improved substatially. I'm pleased with it, but I'd like to see how much power I gained/ time I can shave off before I give it my seal of approval. |
02-22-2014, 02:22 AM | #13 |
Rep 739
What is the OE tune? As in software from BMW?
2009 Alpine White E92 N51 328i Automagic | Premium & Sport Pkg. | Coral Red/Black Dakota Leather Interior | M-Spor | BMW Performance Exhaust | Active Autowerke Headers | BBS CH-R | CPS Front Lip | Performance Front Grills | 888Concepts Custom Headlights (GONE)
2011 Alpine White E90 N55 335i Automagic |
