VP Racing Fuels.
12-22-2013, 01:10 PM | #1 |
Rep 1,093
VP Racing Fuels.
Anyone running super high octane with a JB4. I'm looking at picking up some high octane for the Sled and the dealer is offering me a great deal on MS109 if I buy 3 mini-drums. What blends are you running and what maps.
VP Racing Fuels
07 335XI (A008006) 6AT ~94K miles JB4 G5 ISO VSRF DP's
09 135I M (VK80379) 6MT. Race Project car. 1) Install Cobb/piggyback? and Motiv 600 Kit[HTA3076R w/ tial .82] 2) JRZ or Moton suspension. 3) Build high flow intake manifold with multi-port fuel and relocate OFH 4) Build full cage 5) Complete staged twin setup with HTA4205R [w/Tial 1.16] 6) Complete dry sump system |
12-22-2013, 01:26 PM | #2 |
Rep 632
If your gonna run around with 109 in the tank, throw it on map 7 and hold on! Assuming you have supporting mods!
2007 335i e90 6mt | Motiv 750 XR8267 | RB PCV | JB4 G5 | MHD Pump Flash | Walbro 255lph | VRSF CP & Tial BOV | NGK Plugs | Custom Side Exhaust | CxRacing FMIC | Spec 2+ & SSMFW | StopTech Drilled/Slotted Rotors | Hawk Performance Pads | DEFIV Lockdown kit | Mtec V3 | Apex PS7s | 35/15% Llumar ceramic
12-22-2013, 01:36 PM | #3 |
Rep 1,093
I still have to tear stuff down to see what the previous owner has put in this thing. The 109 is for my sled but they are willing to give me a ridiculous deal if I buy 3 drums. I can't use that much in the sled so I might mix some in for the car. I'm just wondering what people target for octane numbers before wasting money. I can get 94 for 1.35/liter right now and I can get MS109 for under 2 bucks a liter.
12-22-2013, 01:46 PM | #4 |
Rep 2,301
100.
'07 335I w/ Mods
'13 X1 Stock '11 X3 K&N |
12-22-2013, 02:19 PM | #5 | |
Rep 632
12-22-2013, 03:26 PM | #6 |
Rep 691
You can run whatever octane you want, you just need to make tune adjustments (all timing after you've hit that 18/19 psi peak on stock turbos) so you're maximizing the performance potential.
I believe 109 is the highest unleaded octane, so above that there's still gains to be made but you'll be running leaded fuel and killing your o2 sensors. |
12-23-2013, 09:28 AM | #7 |
Rep 1,093
Has anyone had any issues running oxygenated fuel? I imagine because we are DI/FI the gains will be less than I'm used to on carbs. It is sometimes hard on O2 sensors but location has a big effect on this.
12-23-2013, 04:30 PM | #8 |
Rep 691
Just run E85 blends. The ethanol concentration will allow you to run a lot more aggressive timing, E85 is very cheap (vs race gas), and it'll burn cooler so you don't have to worry about timing being reduced mid-pull.
12-23-2013, 04:43 PM | #9 |
Rep 2,301
Actually, straight E85 (non-racing pump E85) has an octane value (R+M/2) of 94-96 octane, depending on the time of year that you buy it. The winter blends contain less than 85% ethanol.
'07 335I w/ Mods
12-23-2013, 04:53 PM | #10 |
Rep 1,093
E85 is not available in Canada from the pumps. I think I could order C85 from VP or something simillar but I'm buying race gas for my sled anyway.
12-23-2013, 09:17 PM | #11 |
Rep 376
I run 104 and e85 mix and map 5-7 it's a monster!!!!
You are limited on how much e85 you can use, without being protuned. 50/50 is awesome.
08 E90 335xi, M Sport, 193M wheels, S1 coilovers, stop tech rotors, Bren tune on E80, 7" FMIC, Catless Downpipes, afe intake, B3 Flash.
"When the turbo's spin the bullshit will end" Team Spin All 4 |
12-23-2013, 09:50 PM | #12 | |
Rep 691
BUT that does not diminish the value of pump E85, as there is a local Porsche making just over 1,000 WHP on $3.65 a gal, pump E85. The biggest "advantage" to Race E85 (or E98) is that you are getting exactly that ethanol concentration, but the power difference isn't as drastic as 93 vs E85. |
12-23-2013, 10:02 PM | #13 | ||
Rep 2,301
'07 335I w/ Mods
12-24-2013, 12:03 PM | #14 | ||
Rep 691
If we were to go by octane ratings, then can anyone explain to me why several pump E85 cars are making the same (if not more) power than cars running C16 or VP Import? Quote:
If you want to comb the internet, their is a forum detailing long term ethanol use on an EVO that was not built to E85 spec. It details a complete tear down of the fueling system & motor. It turned out that everything looked more "healthy" and actually visually cleaner. If I do find it, I'll make sure to post it up Last edited by Mit_Boost; 12-24-2013 at 12:11 PM.. |
12-24-2013, 12:10 PM | #15 |
Rep 691
Dated, but fast forward to 50 seconds in
Honestly, our biggest "concern" with long term E85 use is how the DI injectors will hold up. Last edited by Mit_Boost; 12-24-2013 at 12:15 PM.. |
12-24-2013, 09:35 PM | #16 | |||
Rep 2,301
These two products E10, and E25 are very different from just blending your own gasohol. When you do that you you put in more ethanol than the anti corrosives can counteract. And if the gasoline isn't blended with ethanol to begin with, then you have no anti corrosives at all, in a non-flex fuel car. Quote:
'07 335I w/ Mods
'13 X1 Stock '11 X3 K&N Last edited by Killerfish2012; 12-25-2013 at 09:21 AM.. Reason: spelling |
12-25-2013, 09:24 AM | #17 | |||
Rep 691
There are a very decent portion of forum members here that are running E85 (straight and mixed) as their DD fuel. And there are also performance cars running E85 as their only fuel on several platforms (EVO, Supra, Porsches, GTR, TT Lambo, etc) that have seen no long term negative impacts to running E85. Unless you have any concrete data or proof, please stop trying to pretend there's smoke where there's no fire. Looking through some of your older post, it's clear you just don't like E85. There's nothing wrong with that, but stop trying to convince people it's "bad" when you have no legitimate proof. |
12-25-2013, 09:51 AM | #18 | ||||||
Rep 2,301
'07 335I w/ Mods
12-25-2013, 10:10 AM | #19 | |
Rep 1,257
12-25-2013, 10:12 AM | #20 | |
Rep 2,301
1. It's blended with anti-corrosives equivalent to the 85% ethanol. 2. It's blended using 100 octane race gas, not 87 regular like pump E85 3. It's ethanol content is always 85%, unlike pump E85, which even in the summer, maxes out at 83% ethanol. People on here won't ever use E85R though because it's priced the same as race gas. They'd rather pull up to their local gas station in a BMW, and pump in cheap, government subsidized flex fuel.
'07 335I w/ Mods
12-25-2013, 10:14 AM | #21 |
Rep 2,301
It all boils down to the economics of octane. See post #20.
'07 335I w/ Mods
12-25-2013, 10:34 AM | #22 |
Rep 1,257
I don't currently use e85, and I can more than afford my car. So, if I saw enough evidence to use pump e85 I would be more than happy to save some money dd'ing on that and then using race gas or e85R at the "track". I think it boils down to convenience for people more than anything.
Tags |
100 octane |
