OFT + SSTT. Good or bad?
12-23-2013, 10:35 PM | #1 |
Rep 201
So I recently started running OTS Stage 0 map on my 2007 335i, however I didn't bother taking the SSTT off the MAP sensor.
I don't think I will encounter too many issues with that, but I've also been known to be wrong. Any ideas? |
12-23-2013, 11:42 PM | #3 |
Rep 1,392
Ots map 1 will be 10000% better than a sstt
Have a single turbo and/or tired of burning up O2 sensors? Ask me about the new ADV O2 sensor retro kits!
335i 2010 e92 M-sport Mods: VM Top mount 6466, Aquamist HSF4 w/custom direct port. VRSF IC + Exhaust 335i 2009 e90 665RWHP VFF900 ST RIP . |
12-24-2013, 09:03 AM | #6 |
Rep 248
12-24-2013, 11:26 AM | #7 |
Rep 1,392
A flash tune allows the dme to see and control exactly what's going on without being fooled. With the sstt in place the proper cells aren't be tracked and that is pretty dangerous on a flash tune where the margin of error is a lot less
12-25-2013, 04:49 PM | #11 |
Rep 201
So instead of insults, how about some constructive feedback?
Anyway as I can remember the SSTT only adjusts the MAP voltage reported back to the DME and even then it only calls for the DME to deliver 2 psi additional boost based on the adjusted absolute pressure reading. Wouldn't the flashed DME adjust for that voltage reading regardless? It would be the same as taking a car from sea level to high altitude. I haven't taken a close look at the OTS Stage 0 to see if 2 psi additional boost across the board would cause any major issues. If anyone has real factual feedback, that would be appreciated. |
12-25-2013, 05:06 PM | #12 | |
Rep 1,392
12-25-2013, 05:31 PM | #14 | |
Rep 368
12-25-2013, 10:14 PM | #15 | ||
Rep 2,799
thanks to MGallop |
12-27-2013, 03:45 PM | #16 |
Rep 201
So I pulled a log from the car running Stg 0 with the SSTT.
http://datazap.me/u/ttdmac/3rd-gear-...t?1-3-5-6-8-10 The fuel trim takes a dive as I pass through 4600rpm. Is this something I should be concerned with? AFR is 11.34-44 so it's looks okay if a bit lean. I also notice that I'm peaking at 17.7psi early on and tapering quickly. Is there a reason for the boost to be hitting that early? Constructive feedback welcome. Yes I will be removing the SSTT and doing another pull on Stage 0 and Stage 1 shortly. |
12-27-2013, 04:59 PM | #18 |
3442
Rep 79,211
It said 17.7 PSI but it also had a throttle closure of only 74% TPS at the same time.
11.3 AFR is hardly lean. It's plenty rich actually. The engine may be seeing more then 17.7 PSI but we really don't know since throttle closure inflates boost numbers and the SSTT boost may inflate the numbers also. You are blind when working with the SSTT which is why it's imperative it's removed. |
12-27-2013, 05:18 PM | #19 |
Rep 201
12-27-2013, 05:27 PM | #20 | |
3442
Rep 79,211
Since boost is read pre throttle any closure of the throttle will inflate the boost reading but your engine is not actually seeing those boost figures. This tune will need tweaking to get it right. What exactly I'm not sure. I'll leave that up to the tuner or any OFT users. Have you had any turbo's replaced recently or any other hardware? |
12-27-2013, 05:29 PM | #22 | |
3442
Rep 79,211
Throttle closure creates turbulence and ARTIFICIALLY inflates boost figures. Your tune will need adjustments to fix the throttle closures and / or You should try resetting the DME and all adaptations as that may fix the problem too. It's always best practice to reset adaptations after any hardware changes. |
