Cobb tuner maps
01-04-2014, 01:42 PM | #1 |
Rep 102
Cobb tuner maps
I was running an off the shelf map for a stock 09 335i and I would get a similar situation if you were to blow a coil pack. I uninstalled the map and my car ran great again. I think I may have had a more aggressive map loaded not realizing it. Made my car throw all kinds of misfire codes etc.
Now that I think I know what I did (installing wrong map) can someone recommend a map for a stock 335i that is on the edge before having to mod car for the next stage maps? I had a good map loaded once before and the power increase was insane! unfortunately I don't remember the map I had. Had to uninstall for a service at dealer. Any recommendations welcome. Thanks and Happy New Year! |
01-04-2014, 01:56 PM | #2 |
Rep 707
First off I would consider putting in new plugs depending on what your mileage is and the last time you changed them.
When I flashed my car the plugs fouled and I threw a code. Car had 49k on it and I assume same plugs since new. I ran/was running until my car got totaled this week…the Cobb Aggressive stage 1 with linear throttle…you will be very happy. BTW, if you install new plugs and it still misfires and throws a code, coil packs may be next. GL. |
01-04-2014, 03:12 PM | #4 |
3442
Rep 79,211
01-04-2014, 05:00 PM | #5 |
Rep 102
Thanks,
I should change plugs as I have never and have 42k on car. There are no other mods besides the tuner. Have to run 91 octane as I live in Ca. and that's the highest they sell. Just out of curiosity, can you put airplane fuel in one of these. I think that fuel runs around 115 octane. |
01-04-2014, 05:03 PM | #6 |
Rep 102
BTW all codes cleared after removing cobb. I just want to find the best aggressive map for stock. I would love to go with all the mods I could for maximum power yet maintain as a daily driver. Not sure how far I can go and be legal in Ca.
01-04-2014, 05:15 PM | #7 | |
3442
Rep 79,211
Plugs should be changed every 25K on tuned vehicles. You are overdue. You should only run the map appropriate for your mods and octane. |
01-05-2014, 11:27 AM | #8 |
Rep 1,255
My car is the same year and I live in CA and only have shitty 91. My only mod is exhaust but no down pipes so basically stock. You can run stage 1 sport. You will see a boost and shouldnt get any codes.
01-05-2014, 12:59 PM | #9 | |
Rep 691
The COBB Race Maps (100 octane+) require you be FBO, so don't even bother with those. After the tune, I'd recommend a FMIC to make sure whatever tune you're running is consistent by having quality IAT suppression. |
