**Updated Codes Inside** DTC, ABS, DSC Malfunction.. Need Help!
01-11-2014, 04:47 PM | #1 |
BD_e92
358
Rep 1,748
Okay I am going to need help and advice on this one.. Twice now in the last 3 days I have gotten a DTC, ABS, DSC Malfunction on i-drive with a yellow brake light on also.. After I get the malfunction the car starts to shake violently with the RPM's bouncing quickly.. When I turn the car off and then back on it goes away and the car drives fine..
My mods are: FBO, JB4 + Wedge pump gas flash Map 3: (FUB set to 3) (Meth additive set to 30) (Meth Scaling set to 60) Codes read with the BT Cable were as follows: 2AD0- Gear Control 30FF- Turbocharger Charge-Air Pressure Too Low 2D58- DME digital motor electronics, internal failure, control nominal torque? 2AD0- Gear Control 30FF- Turbocharger Charge-Air Pressure Too Low 2D58- DME digital motor electronics, internal failure, control nominal torque? 2ABC- Charging Pressure Sensor, electrical 3100- Boost-pressure control, deactivation What are my next steps after this?
2017 M2 // Long Beach Blue // Executive // DCT
01-12-2014, 09:31 AM | #2 |
Rep 2,189
Probably too many possibilities.
The first step is really going to be catching it in the act with autoclear off and then looking up codes. Otherwise, someone that had a similar issue will have to chime in. Sorry man. |
01-12-2014, 09:47 AM | #3 |
BD_e92
358
Rep 1,748
Yeah autoclear is off now and I tried to replicate it again all last night, hopefully it was a fluke but it was scary to basically start coming to a complete stop on a busy highway
01-12-2014, 10:58 AM | #4 |
Rep 4,393
I've had that happen but can't remember what the cause was... I think I restarted while driving and it went back to normal but didnt turn off autoclear quick enough. Just so you know if you have the backend flash I don't think you need autoclear on. Someone said that on N54tech and I tried it and haven't gotten a DP code so I just leave it off now
Edit: by any chance did you reset adaptations? I don't really remember but I think that might be where mine happened
< Click picture for photoshoot
E90 335i xDrive 6spd, Nav, Prem, Cold Weather, & Sports package - Msport Conversion Mods: JB4 + MHD, Doc Race ST, Pure 6266, AD-Eng PI/Mounts, Fuel-It st. 3, Custom Exhaust, Tuned by TwistedTuning More Pictures: Build Thread /// 683AWHP/675AWTQ |
01-12-2014, 11:38 AM | #5 | |
BD_e92
358
Rep 1,748
Also I reset my adaptations about a month ago but not recently so I don't think that would have caused it
01-12-2014, 12:07 PM | #6 |
Rep 1,068
I had this happen to me multiple times. My issue was an ignition coil misfire and I was hitting the torque limiter. Have you adjusted your tune at all? I had changed my torque tables and something was set too high. I would suggest you go back to stock tune and see if you get the issue and/or any misfire codes.
335xi
01-12-2014, 02:29 PM | #7 |
Rep 4,393
How are you liking the flash and which timing version are you running? I have the files i'm just nervous and haven't tried them yet
01-12-2014, 07:40 PM | #8 |
BD_e92
358
Rep 1,748
So far I definitely like it, it adds nice low end punch that wasn't there with the BMS flash.. I am not sure which timing file i have but its a pump 93 map
01-12-2014, 11:40 PM | #9 | |
BD_e92
358
Rep 1,748
01-13-2014, 02:17 PM | #10 |
Rep 966
Is this post any help?
TPS, DTC, ABS and Red orYellow Brake Lights all on!? http://www.e90post.com/forums/showthread.php?t=934073 |
