Progman 27.02.02 Rocks
11-03-2007, 10:08 PM | #1 |
Rep 55
Good news. The latest Progman v27.02.02 has a number of much-needed improvements to the iPod functions in iDrive as well as other areas. My 335i coupe (April 2-007 build) received new programming in 18 modules. I had the factory Progman, probably V25. Note that the new incremental upgrades to 20 (the .02.02) are "online upgrades" received by the dealer. They are not documented in the SIB that the dealer has (the release notes for Progman versions). Kudos to Center BMW in Sherman Oaks for putting my car in for reprogramming based on my complaint about slow scrolling in the iPod even though they had nothing in writing that said the new release contained this magical fix. If anyone knows what this upgrade fixes, please post.
- Fast scrolling through Artist and other lists. No more "slow scrolling" problem. Now when I spin the wheel, the list goes gray and switches to numbers that go by very quickly. It used to take me 7-8 minutes to scroll to "Z" artists. Now it only takes about 20 seconds. - Returns to place in list It is now possible to go back logically. Selecting a higher level folder in the secoind line submenu takes you there. Selecting "back" at the top takes you to the list you were in on the entry you clicked. It used to jump back to the very top of the list. - Remembers Playlist after restarting car Now loads audio data and displays full playlist when the car is restarted. It used to display only the current song after a restart. - EQ better balanced with CD and FM sources Now sounds very comparable to other program sources. It used to be too bass-heavy. - Better EQ and cleaner sound overall on all program sources This is hard to quantify without instruments to analyse frequency, but I can tell immediately that the sound is cleaner and the flat setting is now a good starting point. The highs used to have a spitting, brittle quality in the 5k to 10khz range. Now they are cleaner even when turned up. More noticeable is the lack of boominess in the 70-100 hz range. I used to have to drop the 100 hz equalizer slider a lot to clean it up. Now I can use a conventional U shaped "loudness" style curve and get great sound. I need to experiment but it seems that in general it's possible to just adjust frequencies to taste rather than adjusting to make up for deficiencies in the EQ. ...and other improvements (non audio) - Remembers all climate control settings It used to forget if I has the air recirculation on and always went back to free-flow after car restart. Now it stays as it was. - Smoother acceleration Part throttle starts in D no longer produce the little lurch or surge that so many folks have commented on. The throttle feels a tiny bit less responsive, as if the timing was retarded a bit, but it's far easier to drive smoothly. The problem was less in Sport before, but now Sport also seems smoother. I haven't timed it in a 0-60 run but I don't think the car is detuned, just readjusted so thgat launch is easier in real-world and not test-track driving here in SoCal where traffic precludes the sort of aggressive starts that I would normally make if there was no traffic.
Space Grey 335i, ISTA 32.2 with retrofits for lag fix and neutral idle control (Converter lockup clutch disengagement disabled). Sport, Premium, Auto, Paddles, iPod. Nav. Manufactured June 14, 2007, delivered July 21, 2007.
11-04-2007, 01:38 AM | #2 | ||
Rep 3,888
11-04-2007, 03:26 AM | #3 |
Rep 7,519
Drives: 2009 E90 335i MT
First-Second-Third-Fourth-Fifth-Sixth; your choice.
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7 European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269 |
11-04-2007, 10:44 AM | #4 |
this is the way
18363
Rep 8,565
I got my car reprogrammed last week. What did your work order say?
Mine said this.... PERFORMED SIB 65 30 07 REPROGRAMMED COMPLETE VEHICLE INCLUDING CAS. |
11-07-2007, 04:11 PM | #6 |
Rep 18,858
I need to get my nav software upgraded. To the best of my knowledge, my nav software is somewhere around v24.
I have had issues, and Im hoping to get v27 when I bring my car in for its 15k service soon... |
11-07-2007, 04:47 PM | #7 |
this is the way
18363
Rep 8,565
It fixed a lot of issues and is worth your hassle. In addition to what the OP stated it also fixed the little lurch forward when braking that was caused by Comfort Stop. The brakes are not as "sticky" anymore either and it does feel smother.
11-07-2007, 07:41 PM | #9 |
Rep 21,747
Drives: E92 335i TiAg/E46 323i TiAg
AWESOME!!! This is what I was looking for *sigh*... got 27.1.2 *sigh*... should have waited...
Yeah... does anyone have the official bulletin for this progman update?
07 E92 335i | TiAg | Step | Padl | Cmft | Alum Trm | PDC | Nav | Assist | Sat | Lthr | Prem | Sprt | Rear Splr | RDSport Quads | iPod | V1 | LT Refl | VS Clear Bra | OEM Lip | KWV2 | Mtec Sides | BBS LM-R
00 E46 323i | TiAg | 5sp | Sport | Roof | RDSport Cams | RDSport tune | RDSport Shift | Volk LE37 | M3 spoiler | PSS9 | SuperSprint | Brembo |
11-07-2007, 08:21 PM | #10 | |
Rep 7,719
11-08-2007, 01:08 AM | #12 |
this is the way
18363
Rep 8,565
11-08-2007, 01:11 AM | #13 |
this is the way
18363
Rep 8,565
11-08-2007, 01:21 AM | #14 | |
Guest
Rep n/a
Drives:
my brother is jealous of my idrive |
11-08-2007, 07:10 AM | #16 |
Rep 18,218
I really wonder if its just adaptations. My car always seems slow after getting it programmed, then drive it for a week and its back. It could just be it going back to good fuel mileage from the latest progman and then need to be driven hard to go back up to the top power maps
11-08-2007, 10:50 AM | #17 | |
Rep 239
11-08-2007, 10:02 PM | #19 | |
Rep 374
Drives: '05 645Ci Coupe
27.00.00 27.01.00 27.01.01 27.02.00 27.02.01 and 27.02.02 for the e60/e63 series Which one are you refering to? |
11-09-2007, 01:51 AM | #20 | |
Guest
Rep n/a
Drives:
well.... at least my brother wouldnt not too sure. the guy in that link i posted just states "v27" |
11-09-2007, 01:55 AM | #21 |
myfirstbmw335i
17
Rep 349
check out my post about progman..
congrats on a dealer that does the right thing....
http://www.e90post.com/forums/showthread.php?t=94508
2007 335i 6-SPD Sport, Jet Black, Coral Red, Premium, NAV, Cold Weather, Park Distance & Comfort Access, Active Autowerke, Clear Reflectors
IFORGED Essen, Flat Black w/Polished Lip, General Exclaim UHP 19 x 10 275/30/19 (ZERO RUBBING) and 19 x 8 235/35/19, H&R Sport Springs |
11-09-2007, 10:31 AM | #22 |
Rep 18,218
I got my car updated yesterday, and the ipod while it is faster, still takes forever to scroll down the list. Am I doing something wrong? Also it still reverts to the top of the list when going back out to the main menu.
