The 200,000 Mile 335i
01-15-2014, 09:28 AM | #1 |
Rep 1,912
I was on my way home from dinner the other night when I noticed this:
Now enough of this doom and gloom and concern about driving these things past 50k miles. Change your oil every 5k and go have fun! Car's problems: Cracked Tranny Pan (100k, warranty) Water Pump & T-stat (172k) Injector (44k, warranty) Rear wheel bearings (current) Replaced preventatively/for modding: FBO modded OFHG VCG Belt Pads and Rotors Maintenance: Oil every 5k Spark plugs every 60k Coolant flush at 100k Brake fluid every 75k PS Fluid at 130k ATF and Diff fluid every 80k DIY Valve Cleaning at 80k, 130k and 190k Last edited by PINeely; 06-22-2014 at 11:43 PM.. |
01-15-2014, 09:35 AM | #3 |
Rep 1,912
01-15-2014, 09:40 AM | #4 |
M-GAM3
240
Rep 1,264
You need a Diesel. But good to know you are probably one of the few to put that many miles on a 335.. Write Bmw NA when you make it 300K..you might get a gift..
Car Enthusiast.
01-15-2014, 09:49 AM | #7 |
Rep 447
01-15-2014, 09:54 AM | #8 |
Rep 644
I am 400 miles away from 100k and replacing my water pump and thermostat this weekend. I have been paranoid about failure since about 60k and everyone I talk to has had it fail way before 100k. Your 172k on the pump makes me think I am wasting my money. Anyway, it is a DIY and the cost is $450 total. I've wasted money on worse and I will feel better about taking long trips which are fantastic in the 335i.
01-15-2014, 10:06 AM | #10 | ||
Rep 1,912
There is a DIY somewhere which I followed but basically I took the intake mani off, found which cylinders had valves closed and filled them up with carb cleaner, let sit, scrub off with gun brushes and wire brushes, suck out with shop-vac. Then just turn the crankshaft to move valves and close the other cylinders, repeat for them. It's very easy to do but it does take a few hours. |
01-15-2014, 10:44 AM | #15 | |
Rep 1,912
JB4 Raceland Downpipes ER Intercooler Injen DCI ER Charge pipe Forge Diverter Valves Riss Racing OCC (I think they're out of business now) |
01-15-2014, 11:45 AM | #20 |
Rep 722
Drives: 2008 BMW 335xi
Very refreshing to see this. Also 172k for original water pump? Must be a record.
01-15-2014, 12:11 PM | #21 |
BMWCCA 149159
38
Rep 847
There is no reason we should be replacing water pumps like we are but I think the conditions you have are the main reason. I don't drive short distances and never in salt or cold weather but I keep a new pump and tstat in my trunk.
I have the OFHG leak and the trans leak both which will be addressed soon. I think your OCI of 5K is key to not getting an overwhelming build up of carbon on the intake valves. I sold my M3 last year with 284K miles to a friend with everything running just fine to include every switch and control... I do all my own work but was planning to have the valves done with the OFHG but thinking I might just do those myself now. Congrats on the miles!!!! |
01-15-2014, 12:26 PM | #22 |
Rep 4,725
I have 112,000 on mine and still going strong!
But I just ordered a 435... :-(
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
