Dyno results proceede rev3 w/Flash , E30, DP, DCI
01-19-2014, 12:51 AM | #1 |
Rep 53
Car made 387/404 . Does this sound about right? I think it's kinda low. I have a few datalogs I did with a 50/50 mix prior to this dyno .
Anyone want to help to see what adjustments I can make http://datazap.me/u/bmwFbro |
01-19-2014, 04:58 AM | #2 |
Rep 923
What maps are you running on the procede? Those datalogs do not look like the aggressive maps and you had timing correction higher than it needed to be for running an ethanol mix. You made the appropriate amount of power for the boost and timing you are running. There is a lot of power left on the table right though. If you didn't do a baseline dyno, there is nothing to compare your results to though so it will be difficult to say if your numbers are correct or not for that particular dyno.
