How many miles you guys have?
01-19-2014, 06:26 AM | #1 |
Rep 77
So my 2007 335xi now has 96,000 miles on it. I'm just wondering if there are a lot of high mileage n54 335i/335xi out there. I also wonder who has the car with the most miles on it. I think I've read someone got their 335i to 200,000 miles before, which is amazing !!!
01-19-2014, 12:14 PM | #6 |
Rep 372
09 335i with 86K.
DTML Pump @ 65K Oil Filter Housing Gasket @ 65K Precat O2 Sensors @ 69K Valve Cover @ 70K Front Lower Control Arms @ 70K Rear Wheel Bearing @ 74K Last edited by Ch3ss; 01-19-2014 at 01:53 PM.. |
01-19-2014, 01:11 PM | #9 |
Rep 1,084
2010 e92 335xi 56k
2 hpfp Leaking oil gasket @ 32k New injectors twice Cobb tune since 40k (stage1) Cobb stage 1+ (dinan fmic + intake + BMW PE) @ 47k PTF tuned since 52k FBO for about 3 days |
01-19-2014, 01:15 PM | #11 |
I Can't Drive 55
129
Rep 883
Drives: 2008 BMW 335i (E90)
Garage List 2023 VW ID4 Pro [0.00]
2002 Ford F250 7.3L ... [9.50] 2008 BMW 335i [0.00] 2012 Mercedes ML350 [0.00] 2002 Toyota MR2 Spyder [0.00] |
2008 335i E90 with 86k miles -- only 700 mine so far --- and it runs fine.
Mishimoto IC w/Cobb Stage 1+FMIC LT Sport map w/K&N filter installed over PPK Stage 1 flash which was saved in Stock map. No maintenance or repairs required yet. |
01-19-2014, 01:23 PM | #12 |
Rep 1,392
2009 e90 82,xxx miles
ST'ed for about 10Kmiles original water pump original thermostat original HPFP New injectors New Coils Was FBO for many many miles before that. I have no complaints at all about reliability or problems with as much hell as I give it
Have a single turbo and/or tired of burning up O2 sensors? Ask me about the new ADV O2 sensor retro kits!
335i 2010 e92 M-sport Mods: VM Top mount 6466, Aquamist HSF4 w/custom direct port. VRSF IC + Exhaust 335i 2009 e90 665RWHP VFF900 ST RIP . |
01-19-2014, 04:41 PM | #16 |
Rep 1,328
A 2011 e90 335. Literally just passed 130k yesterday. Dinan Stage II. Have not had a single problem with the car ever. I do most of my own maintainence and follow a proactive schedule.
01-19-2014, 04:44 PM | #17 |
Rep 2,771
Holy shit. What's your commute like. Your car is 4 years newer than mines with almost twice the mileage.
01-19-2014, 05:18 PM | #18 |
Rep 1,834
Drives: 08 E90 335xi TiAg
2008 335xi E90 6AT w/ Alpina flash and full coding.
80k Just replaced water pump, thermostat, oil filter housing gasket. Also had to replace that silly plastic coolant tube that runs over the top of the radiator. It ruptured on the freeway last week. Towed and fixed...next day water pump failed....towed again. Rough week. Transmission pan, filter and fluid, front/rear differential fluid at 79k. New OEM turbos via factory warranty at 78k. Walnut Blasted 78k New coils 80k. Plugs 78k Oil/filter every 3-4k miles. fmic, DCI, OCC. Suspension koni. Cobb PTF E40 Hoping after I installmy walbro 255 inline I will be out of the woods for a while. Been an expensive couple of months. Love my car when it is trouble free! |
01-19-2014, 06:34 PM | #19 | |
Rep 77
01-19-2014, 07:03 PM | #21 | |
Rep 1,834
I did the OFH gasket myself and gasket was around $10. |
01-19-2014, 07:10 PM | #22 |
Rep 1,834
I'd do it, bimmerman..... piece of mind. Had a humming whine and its gone now.
