RB's with nitrous? 550-600whp doable?
01-27-2014, 11:01 PM | #1 |
Rep 502
RB turbo's with a 50 or 75 shot of nitrous? Just curious if it would be possible to achieve that much power or am I talking crazy? since RB's/Vargas stage 2 are already making over 500whp
01-27-2014, 11:16 PM | #2 |
Rep 1,392
I wouldnt risk even trying with the small exhaust/turbine section. EGTs and EGP would be extremely high.
Have a single turbo and/or tired of burning up O2 sensors? Ask me about the new ADV O2 sensor retro kits!
335i 2010 e92 M-sport Mods: VM Top mount 6466, Aquamist HSF4 w/custom direct port. VRSF IC + Exhaust 335i 2009 e90 665RWHP VFF900 ST RIP . |
01-28-2014, 12:50 AM | #3 |
Rep 6,478
Wouldn't bother with le nitrous on a stock frame setup. Like ^ this man said- you'll smoke something.
But yea you could make the power for a glory run.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
01-28-2014, 07:02 AM | #4 |
Rep 1,257
I agree with 3000GT MR, and am not even sure you could make the power in the first place. Can the RB's even push enough air for that power level to keep safe AFR's with that effective octane?
01-28-2014, 07:33 AM | #5 |
Rep 1,950
Drives: 335i
01-28-2014, 10:51 AM | #6 |
Rep 2,856
Drives: 2011 335is E93
I'm sure there are plenty of guys who push over 500whp with RB's, but they are running Ethanol for cooling.
It's definitely doable, but likely more prone to something breaking considering those small twins are hybrids, but not meant for that kind of abuse lol. |
01-28-2014, 11:07 AM | #7 |
Rep 2,799
I believe someone hit around 500/500 on stock turbos and n2o, I'm sure if you didn't mind diminishing returns then you might be able to squeeze 550.
thanks to MGallop |
01-28-2014, 02:50 PM | #9 |
Rep 368
I suggest looking at other forums and having a conversation with someone that goes by the name of "georgesmooth." Hes from S. Africa and was running RB's with nitrous many moons ago. If it wasnt for his auto trans grenading, he would have probably cracked 550 easily.
01-28-2014, 08:22 PM | #10 | |
Rep 6,478
The motor should take nicely to nitrous, didn't someone at AR Design throw some nitrous at the N54 with nice results? A few folks have done small wet shots.
01-30-2014, 09:51 AM | #11 | |
Rep 1,153
2016 340i xdrive
2009 335i |
01-30-2014, 10:56 AM | #12 |
Slow.
3782
Rep 7,152
Drives: Single Turbo N54 on Meth!
Since our turbos spool up instantly there really isn't a need.
On a larger ST I can certainly see a shot helping them off the line.
01-30-2014, 11:18 AM | #13 |
Rep 6,478
Good point, not like the stock frames suffer for spool. Someone with a 6466 or GTX35 needs to see what a medium sized wet shot would do for spool.
01-30-2014, 04:43 PM | #14 |
Rep 565
I ran a kit on top of the RB's . Over 550whp (1.4mm jet and 1.2bar) the exhaust housing is to small to expell the gases and boost starts to creep. In my case I was getting in gear slippage on the auto with a 1.2mm jet and am still waiting for a transmission solution to hit it again.
We dialed down the kit to a smaller jet and 500whp (RB's max out at 480 at me altitude) and the my box was still slipping on the gear changes. The issue is the tranny doesn't see torque produced due to the algorithm not taking the nitrous flow into account. This is my theory because without the nitrous and at 500whp and more torque I get no slippage.
08 E90 335i AT RB Turbos -NX Wet Kit - Chiplogic Flash or Procede V5- M3 Diff - AE Exhaust- Forge Dv's - Helix Intercooler - AR DP's - P3 Boost Gauge - Vishnu Meth- Stett Chargepipe and CAI
09 C63 |
01-30-2014, 06:07 PM | #15 |
Rep 911
Hi George,
I have done a shit load of study on the gearbox, including contacting car DME programmers in India to see if they could help out... The TCU encryption is just to heavily encrypted at this moment and the costs for the appropriate tooling will be around 5000 - 10000k euro to start hacking. So waiting..... I was in the same situation and a ZF mechanice took a deep dive into my box. What we noticed was: - When the box oil ever overheats above 100 degree celcius your internals (plates) are more or less shot for life due to the fact that the oil is not longer working at that moment. - You can dump the complete TCU history / KPI and this will give you a pretty solid view on the cause of the damage ( I bet oil overheating resulting in progressive wear) -When the plates starts slipping the damage is already done, you will need at least new plates - My box was slipping after 100k km's. But when we took the box apart the gear 1-5 especialy 1-3 were literarily gone. It seems that the TCU can compensate quite a bit of wear - With the rigth contacts it should be possible to rebuild the gearbox for about 2000-2500 euro's. Given that I did 80k km''s without noticeble damage this seems to be the best route. - When warming up the car, your gearbox temp is about 20 degrees celcius behind your engine temp. This means that you need at least a 5 minutes longer warmup on a cold start after the engine is a 80-90 degrees. (This and the procede launch control which I tried twice cause most damage, although having a burned down 5 gear indicates wear caused due to high load, (Track / Autobahn) but gear 6 was pretty good in shape (Constant driving with sufficient cooling) Long story, the ZF engineer adviced to rebuild with standard parts, upload the alpina software and add serieus cooling. As long as the oil is ok your gearbox will do a pretty good job. For the TS: I did 100k with my RB's... big difference with stock, more torque, crazy amount of power between 5000 and 6500rpm. No experience with ST, but the RB's are in great balance with the car, it transforms the car from a fast car to a kind of sportscar while keeping things very driveable...
BMW 335 E92 09 - Full options - DKG - MHD by Buraq - RB Next Gen - RB Inlets/Outlet - Forge Diverter Valves - AR Catless DP - Afe Intake - Helix IC - FuelIT Stage 2 LPFP - Ar Oil Cooler - PPK Water Cooler - M3 Suspension - JRZ RS1 Shocks - Eibach Pro Springs - Drexler LSD - BMW IS Exhaust - Carbon Endurance Brake Pads - Stainless Steel Brake Lines - M101 Wheels - Michelin PS2 - M-Tech Body - M-Strutbar
BMW M550i G30 2019 - BM3 |
01-30-2014, 06:19 PM | #16 | |
Rep 3,736
01-30-2014, 07:37 PM | #17 |
Rep 565
I have had the Alpina flash on the car from 2009.
09 C63 |
