Low Windshield Washer Fluid Warning
12-16-2005, 02:08 PM | #1 |
Rep 43
Has anyone had their light go off? It seems to go off when there is still 1/3 of the tank full. Mine went off and I was only able to put about 4 litres in there when capacity is 6 litres.
12-19-2005, 04:03 AM | #4 |
Vroom Vrrooooom
303
Rep 3,146
Drives: 330i
Got the light, whent to Advanced Auto and bought a gallon of RainX brand defrosting fluid. The tank took the entire gallon no problems. I didnt notice any light problems.
-Dmitriy
06' BMW 330i & 03' Suzuki GSX-R600 SG | Beige Dakota | Poplar || iDrive w/MP3 | PP | SP | CWP | PDC | Comfort | Shades || 40% Tint | Black Line Tail Lights | Hardwired V1 |
12-19-2005, 05:22 PM | #7 | |
Rep 1,044
12-19-2005, 10:59 PM | #8 |
Vroom Vrrooooom
303
Rep 3,146
Drives: 330i
I was surprised, but then I figured they had to design a huge tank because when ever I use my washer fluid with the lights on, the high pressure headlight washers kick in and take two seperate sprays. So you figure two sprays for 2 headlights plus the windshield. The factory gallon lasted me 3 months, ~3200 miles.
-Dmitriy
10-12-2010, 12:16 PM | #9 |
enthusiast
Rep 57
Has anyone noticed a really short interval between fills?? My low level light went off about two weeks ago, and I added a whole gallon of washer fluid. For some reason my warning just came up again this morning...?
I really hope it isn't a leak or something |
10-12-2010, 02:34 PM | #10 |
I ask the questions you're afraid to ask.
44
Rep 2,489
How often have you used the washer? With the lights on?
11-17-2010, 07:40 AM | #13 |
Rep 1,063
11-17-2010, 09:08 AM | #14 |
I6 + TT = FTW
99
Rep 860
You need to go to the dealer and register the new washer fluid, same procedure as getting a battery. That will dim the light.
(jk, how ridiculous would that be..) |
02-27-2011, 09:44 AM | #16 |
Rep 407
I started getting this problem today.
Filled the washer reservoir completely and the light still won't go off! Is this a common problem?
04-02-2011, 11:04 PM | #19 |
08 335i
24
Rep 330
My light came on about 3 months after completely filling it myself, and I used the spray *maybe* once. I had the dealership fill it up for me during a normal maintenance, and within 3 months the light is back on, after *zero* spray use. I have never noticed any signs of a leak from under my car, but am starting to think it is definitely leaking somewhere..
05-10-2012, 09:52 AM | #20 | |
Old Timer
Rep 69
I just picked up a 2009 BMW 328 and I see the same thing. I top off the fluid every two weeks because of the low level light kicking on. I only spray the washer fluid maybe 2-3 times during those two weeks. No leaks anywhere that I can see. Is it normal to go through that much fluid? Or is it the head light washers that kick on and I just dont see how often they spray? Exactly when do the head light washers spray? |
05-10-2012, 10:47 AM | #21 | |
Rep 5,627
"When the vehicle lighting system is switched on, the headlamps are cleaned at regular and appropriate intervals." In real life it seems to be about every 4 or 5 times the windshield is washed. It sounds like you have a leak as my E91 with rear washer and headlight washers needs to be refilled only about every 5,000 miles or so. Tom |
