E90Post
Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Throw out bearing stuck!
Reply
      02-15-2014, 12:59 PM   #1
HeavyMetalRocker
HeavyMetalRocker's Avatar
Drives: 2007 BMW 335i E90 6MT
My car is over at Cobb Plano getting a spec 2+ installed and they called me telling me that the stock throw out bearing is stuck... Anyone have any experience with a stuck throw out bearing? If so, what did you do or what was done?
2007 335i e90 6mt | Motiv 750 XR8267 | RB PCV | JB4 G5 | MHD Pump Flash | Walbro 255lph | VRSF CP & Tial BOV | NGK Plugs | Custom Side Exhaust | CxRacing FMIC | Spec 2+ & SSMFW | StopTech Drilled/Slotted Rotors | Hawk Performance Pads | DEFIV Lockdown kit | Mtec V3 | Apex PS7s | 35/15% Llumar ceramic
      02-15-2014, 04:09 PM   #2
rdeterman
rdeterman's Avatar
11
Drives: 2008 335i Coupe 6mt
yes.. mine was stuck too. They had to get a chisel and carefully cut it apart piece by piece. Its not fun.
JB4 G5 ISO W/BMS FLASH, FBO, Walbro LPFP, Spec S2+ SMFW
      02-15-2014, 05:37 PM   #3
HeavyMetalRocker
I got an update that it's the pilot bearing that is stuck and not the throw out bearing.... either way my car isn't and won't be ready...
      02-15-2014, 06:58 PM   #4
fdawg4l
0000000
Drives: E90 335i 6MT
Throw out or even pilot bearing being stuck sounds weird. Do they have the trans out to even see it? At that point, it's cheaper to replace the whole clutch, pressure plate, and all the bearings (which come in the kit) as well as the fly wheel than it is to replace whatever bearing is screwed and put it back together.
Idunno. I trust cobb, but that sounds really weird. I'm guessing they're saying the car is stuck in gear, right?
      02-15-2014, 07:19 PM   #5
rdeterman
rdeterman's Avatar
11
those bearings get stuck all the time. Its not unusual
      02-15-2014, 08:36 PM   #6
HeavyMetalRocker
It's at Cobb getting all of that put in. It's the stock pilot bearing that won't budge... They had it apart this morning and told me they couldn't get it out... Then called me at 6 and said they still couldn't get it out and that they had to call their Snap-On tool guy to have him bring some special tool on Tuesday since their closed on Sunday and Monday... All just stop they can install my stuff.... Huge pain in the ass
      02-16-2014, 08:14 AM   #7
Rotorocious
Rotorocious's Avatar
103
Drives: 335xi
Had the same issue.
Tried the grease pressure trick, in the end we had to cut it out
      02-16-2014, 09:57 AM   #8
cwarren
cwarren's Avatar
82
Drives: 08 e92
dont think I have heard of anyone being able to get these out easily this really does require a special puller with a very fine grab to it . you would think cobb would of had the tool as this couldn't have been there first pilot bearing on a bmw
ptf MHD E85 /Hexon rr550 turbo's/PRE custom intakes/CP / bms dp's/hfs4 / er fmic/PSS/spec stage 2+/kwv2/steveAZ stage 3 lpfp /m3 control arms/powerflex black/MF LSD /fuel it port injection
      02-16-2014, 11:09 AM   #9
Joshboody
Drives: pickemuptruck
BMW should have a specific tool. One member, GeorgiaTech, used a harbor frieght slide hammer kit successfully after trying various other methods.
      02-16-2014, 02:44 PM   #10
fdawg4l
0000000
OOOH! I misunderstood. "stuck..." while getting upgrades or some such. Got it.
yeah, mine was a pain getting out. We had to use a slide hammer and be pretty unkind to it, the bearing, the inputshaft, and anyone within an earshot.
It took a few hours, but the slide hammer did the trick for me. The grease-gun method wasn't getting me anywhere but...sticky.
Good luck, man. Get some pics if you can. In the end, this will just be a good story.
      02-16-2014, 02:50 PM   #11
fdawg4l
0000000
That worked for me too. Same tool, i believe too.
The trick was to use the slide hammer attachment with the teeth that rotate outward as you screw it onto the slide hammer's shaft. It's too wide on their own to just slide in to the PB, so we had to use a punch to get one of the pins of the fingers out, slide the remaining attached tooth/finger into the PB (a friend is handy here since the hammer itself isn't exactly light), slide the removed finger in, pop the pin back in, then spread the fingers. In the end, it's a really crappy mechanical connection to the PB and it'll slide away from the PB with every hit of the hammer, but in doing so, the PB itself will come out a little.
We trashed the inside of the PB, but it did come out far enough to grab it and pull with vise grips.
      02-16-2014, 04:26 PM   #12
HeavyMetalRocker
It's at least good to know I'm not the only one! Yeah they have a guy from Snap-On bringing them some special tool on Tuesday so hopefully I get my car back then... Damn glad I didn't try this install myself lol
Reply
e90post
